GMS1 users
GMS1 users
Looking to see how much a FBO GMS1 car makes. Not looking to make big power or push limits. I just want to be able to add parts and such without retuning and logging etc etc. Looking to do a catted DP, charge pipes, ic, k&n intake. Any idea how much this should actually push? Dyno numbers are good. I know with stock everything about 250-260 is what you get. Like I said it's just to be able to add and remove parts as necessary and not need retunes. I also don't want to push limits on a 100k mile unknown history motor. Safer the better.
What does FBO mean?
A bone stock GMS1 car will make about 260-270whp 290-300wtq
With a high flow down pipe and either the zzp intake pipe and k&n filter or K&N SRI.
They make between 280-290whp 290-310wtq
All that being said you could get a zzp canned tune with gms1 sensors and make close to 300whp with relative safety and save $$
The gms1 tune won't account for anything- cai, downpipe etc. it would be a waste to really add anything as gms limits the engine. Custom tune is better. Gms1 is ok but adding boltons won't get you anything.
Originally Posted by slapbetcommissioner
What does FBO mean?
Just to give you some information.
Stock clutch is rated for 320 ft-lbs.
I have a 2009 cobalt ss with 95,000+ miles. Car has K&N intake, ZZP upper charge pipe, TR8 intercooler, High flow catted Downpipe, Turboxs cat back exhaust, Forge diverter valve.
The car was tuned on HPtuners at 46,000 miles with a 20 psi tune. The dyno read 297 whp and 327 trq at the time.
The car was retuned a few thousand miles later for 24 psi tune with Hptuners. It has been tuned for about 50k miles at 24 psi with no issues. I am still on the original factory clutch with no sign of slipping.
I have two ECMs as I had a spare ECM that recieved the 20 psi and 24psi tune while I left the original ECM in my car factory "tune".
I can interchange for the factory "tune" ECM and the HPtuned ECM with little change to the AFR and fuel trims. The worst the fuel trims got this winter on the factory tune was 7-8+ LTFT.
I usually put the factory tune on for winter months with my all season tires and use the 24 psi tune for the spring and summer with a Summer tire. been doing this for the past 5-6 years. No CELs, no issues.
Take this info with a grain of salt, not all engines are exactly the same and react the same.
Originally Posted by T-Man
No, it doesn't. It raises the targeted airflow/torque ceiling somewhat but is still limited. Especially over specific RPM points.
Good luck to you in your quest.
Ultimate goal is GMS1, K&N SRI, ZZP charge pipes, ZZP IC, YYZs with FE5 front and Koni rear (have these), new control arms with Powell spherical (have these too). Then fix the small issues it has for the age, and TOTD if I can make it.
Why not just get GMS1 and nothing else? There is really no point in adding a downpipe or intake if you don't tune for them. You'd be effectively spending money for nothing.
Something about gms1 has me on the purist approach. Like gms1 is the performance package GM had so that's how they wanted their performance package to be. I'm okay with that. Keeping it as close to stock as possible and slaying what I can is good enough for me.
Adding parts should still allow some gains though, no? If I go custom tune I risk staying stock. Which is what everyone who's car keeps breaking keeps saying. I can't have it break every other day. Less power more handling focused is how I want to go. I don't want to put all my money into a custom tune and fbo when I have suspension parts in my house waiting for the salt to wash away.
You may see some gains adding those parts with GMS1, but as T-Man points out it is severely limited in areas, going with a quality tuner that gives **** will net you a better tune than GMS1 with the mods you're adding. But if you get a copy paste tuner then you'll likely have a boost spike and all kinds of other **** issues.
T-Man (02-28-2017)
It would be more like spending little by little once every couple months. That's my point, with a custom tune I'd need to get retuned every time I change something. With gms1 I can add all the things and it'll still be fine.
Also you don't need a tune change from charge pipes, intercooler, or downpipe. Will it extract a few extra hp if you do tune for an intercooler and downpipe, sure, but as you've pointed out you don't want all out power. So no need for a retune at each part addition, you certainly should tune for the K&N or leave the stock box if going with GMS1.
T-Man (02-28-2017)
Originally Posted by ECaulk
You are contradicting yourself in this post.
GMS1 does not compensate for an aftermarket intake. You will see an AFR skew. Now again I mentioned running my car on the stock tune with a K&N intake and not having any issues. So it may or may not show as bad of a skew to cause a CEL.
My car runs fine with no tune and all the bolt ons. Been doing it for years in the winter months (November - beginning of April, depending on temperatures).
Which means you could put all your bolt ons on over time and then tune when your ready. Make the Intake the last bolt on item which would be the one that most likely would cause the issues.
Honestly I dont care, GMS1 is a fine tune, been thinking about updating my "factory ECM" with one but then Id have to retune the HPtuned ECM since new sensors and what not. I dont know if Backyard Turbo is still tuning cobalts or not either.
Probably still going to GMS1 and stay stock till I have the funds to go all out. I just want a little more boosta.
Yes I am on the stock 2.5 bar MAP sensors. Not the GMS1 sensors. (BYT) Nick tuned my car. I know he moved recently and his website says their not doing any tuning till Spring of 2017 to sort personal things out.
His tunes are solid and the car will move out quick. If you were to get tuned by him, id make sure to tell him you dont want any boost spikes and would like boost/ torque limited 1st gear to keep the car daily driveable.
My first 20 psi tune was a huge boost spike and 1st to 2nd gear was undriveable. Tire spin city as well as very jerky. He retuned me to 24 psi for another issue tho and I happened to ask him to clean that part of the tune up.
The first tune was rushed as it was a dyno day event. He basically tossed on a base tune and did not have enough time to clean it up. A drive to South Carolina revealed a slow Fuel trim creep which eventually threw a code. re-verified that on the drive back from South Carolina as well. He updated the tune, no charge on his own time. Good guy, and a good tuner.
The difference between a custom tune using HPtuners and GMS1 is that GMS1 feels stock still but more agressive. Custom HPtune feels like a whole new car.
CudaJoe (02-28-2017)
Yeah I ran bos with stock tune for like 2 or 3 months before I got tuned, it's not the longest time but the car was fine and I'm sure I could of gone longer without tuning, but it made a great difference once tuned, I've been tuned since 70k if I remember correctly I'm at 104k with 2 turbo swaps now lol
