GMS1 users
Unsure of the motor condition. Been doing small things like cleaning the TB and MAF and running seafoam to make sure it's good inside. Did a Compression Test and was about 150-160 so that's also another factor. It's not a new motor. It's all in the quality of the motor and the tune.
I've been running a K&N SRI untuned for probably 2 years, with no CEL. I do have HPTuners, catless dp and 3 bar sensors to install though, I just need a place to do it.
Oh I know they are super dirty, just haven't had the time or motivation to do them (plus they aren't giving me problems yet) and also I would want to have the Powell air/oil separator before I clean them (that's actually the main reason I haven't done it)
#37
#38
Originally Posted by umrdyldo
K&N SRI doesn't skew the Long Term Fuel Trim by much at all. 2-3%
But under full throttle my car was off by 8-10% for short term fuel trims.
I basically took GMS1 and cleaned up my fuel trims. Car seems to like it.
#39
LNF Guides
#40
Update:
BYT is flashing me GMS1 for $150! Thanks to the guy above me (I'm on mobile I can't see your name) for linking me that forum which showed me that BYT did work with gms1 before. So I reached out and asked and he'll flash it for me!
This will suffice for now then when I'm ready to custom tune I'll go back for a custom tune and it'll already be HPT unlocked through him!
CudaJoe (03-01-2017)
#42
Glad he's still helping the community. Yeah it's $100 to just unlock your VIN so $150 is reasonable.
#43
All tunes will have the "learn down" feature still in effect. It is the very nature of the airflow and torque request type ECM that we have. You can make the tune a bit more or less sensitive to this effect by using a few different ways of effecting boost, but it is still there because the ECM is always looking for target airflow. The GMS1 tune functions just like the stock tune for how it works, but just adds some more boost and more timing to make more power.
For the GMS1 tune (compared to stock) they keep mid rang boost limited to about 16-17 psi, then creep it up quickly as you approach 5000 rpm to about 20-20.5 psi (weather dependent of course since it is looking for a target). Maybe spool the turbo a bit quick (more aggressive PID tables that control the wastegate), but nothing crazy. And adds some ignition timing for a little more power also.
I can tell you that for what you want I would just get a IC for reliability concerns only (plastic end tanks can explode as boost goes up, ask me how I know), and a custom tune. You don't need anything else. You could get a few bolt ons like the DP or intake, which would allow you to make the same target power at a little less boost, but not really necessary for what you want. I almost went with BYT because I could drive there pretty easily os he could tune in person. He said he normally sees about 300-310whp on a completely stock car, if the engine is healthy.
But I decided to go with HPT and learn it myself. Difference between a custom tune and the GMS1 is night and day. I started with a GMS1 tune and the car is a completely different animal just by the new tune I have. I decided to tune to about 23psi, and was able to add in about 3.5 degrees of ignition timing (compared to GMS1). That makes a nice gain over GMS1 for sure. I ramp in boost faster than the GMS1 also, but not so crazy as to make the clutch slip or worry about blowing up my trans from torque hitting to hard. A good tuner can do whatever you want, so you can ask to make more than the GSM1, but keep all the safety features it has like over boost protection, modest boost ramp so there is no boost spike, torque limit in 1st gear, etc. You don't need to have a custom tune be any more dangerous than a GMS1 really. The GM tune is even a little lean from my research, so a custom tune can fix this my going a tad richer (GM did not get everything perfect on even their tun).
I just see you putting a lot of faith in the GMS1 tune. Not that it is bad, but I don't think it is necessarily an more reliable than a custom tune (if you ask for a conservative custom tune), and it is not any better at reacting to BO parts than a cutom tune since they all function by the same math models and tables in the ECM.
Hemphog (03-08-2017)
#48
Ive also heard of people just using brushes and cleaners through the ports not walnut blasting. I'd probably set up newspapers around your engine bay and especially around the bottom of the intake ports going to the radiator fans to catch gunk. And the floors obviously. It's a time consuming process.
