GMS1 users
#52
Mine seems to idle reasonably well even when cold, hardly a stumble and not "that" rough. Seems perfect when warm.
I am sure there is a few HP loss when they get dirty and start to restrict airflow some, but the car runs like a BOH still, so I have not seen it worth my time until something gets more affected. At 149,300 miles now (HP tuned).
#53
The only real reference we have is an Audi that dynoed before and after. Gained 55hp and 25 torque on a 350 HP engine. I would think 10-20 HP depending on age is definitely possible. The 1-2mpg increase is enough for me to do it every 3 years. First time I did it I used walnut blasting. Second time I used GM Top end cleaner only and let it soak for an hour. I much prefer the soaking method. Half the time half the work. Similar results. I just buy a good cleaning cut and go to town
#55
BYT recommended mopar combustion cleaner. Works the same as seafoam top engine cleaner. Spray into the vacuum line on the intake mani and let it soak with the car off for 10 mins. I'm buying some tomorrow to try it out. He said it should smoke a good bit after the 10 mins of soaking.
#56
You are much better off to remove the residue and vacuum/pick it out than ever let it enter the cylinder. Especially when you spray and at least one of your cylinders is open.
Don't be lazy. This job can be done for $100 including beer
#57
Originally Posted by umrdyldo
I personally wouldn't do that. Major reason is that the oil crud on the valve is rock solid. You would think soaking it would dissolve it into liquid again. It doesn't. It flakes off in hard chunks. I have seen pictures of cylinder walls that get scored by people that clean their engine this way. It gets caught on the rings and eats up the cylinder wall which could lose you some compression.
#63
Or the likely difference, the wideband pulled enough fuel from the injectors that it wasn't running pig rich.
Seafoam doesn't do much in the short term, the stuff crc makes for direct injection makes a bit of a difference, but thats only if there isn't a thick layer caked on already. Buy a cheap borescope and pull the brake booster line and take a look.
#64
#66
You take the brake booster hose off, then unscrew the nipple for that hose and you will have a big enough hole for a borescope through the manifold. Much easier than pulling the throttle body.
#68
rotating an electric throttle body's blade is a good way to make you have to buy a new one. some people get away with it with no issue, others end up buying a new throttle body.
Going through the brake booster nipple you'll have a straight (damn near) path to the intake valve runner
#74
Originally Posted by T-Man
Pull the IM off yourself and clean it by hand. It's easy. Time consuming but easy.
#75
Using what cleaners? Don't want to ram carb cleaner in there just to find out it wasn't the right one to use lol. Probably going to end up going this route. It's the most cost effective and I can do it on a weekend. Now to protect oil from getting back in? What kinda catch cans do you recommend? Not using powells system solely because it costs a small fortune.
