How to disable TPMS?
Old 04-08-2011, 08:07 PM
  #51
rukkee's Avatar
Originally Posted by VinceTrifecta
If someone out there has a Cobalt SS with the TPMS light on and also has our EZ Flash cable, could you send me email if you're willing to help test it?
My email is rukkee@toast.net if you want me to do it . I might not be the best candidate because mine is so intermittent but thats up to you......... thx for all the work you've put into these things 8)
Old 04-09-2011, 01:01 PM
  #52
Sweetsandman's Avatar
Just let a lot of air out of one of your tires. That will trigger it guaranteed.
Old 08-02-2011, 12:41 AM
  #53
apicia's Avatar
Did you figure this out Vince?
Old 02-09-2012, 10:27 PM
  #54
KoriCobalt's Avatar
I hope there is a solution to this problem by now
Old 02-09-2012, 11:18 PM
  #55
apicia's Avatar
He did figure it out, but did not integrate it into his software yet...
Old 02-10-2012, 01:00 PM
  #56
chickenbop's Avatar
Yeah-I just emailed them 5 days ago and got this response
"We don't have the TPMS disable feature finalized yet, but we can definitely
tune your car for you."
I'm waiting till they have the tpms delete to buy.
Old 02-11-2012, 11:38 AM
  #57
guitarenvy's Avatar
Not sure if anyone else posted this already but there is one method that will "disable" your tpm light on the dash. Its the most easily reversable way to do it and the best method to run winter rims with no sensors.
You will still require 4 working sensors.
Im not going to described the entire procedure but you can google it.
Build yourself a small sealed pcv pipe with threaded caps at the ends. Just has to be big enough to hold 4 tpm sensors. Install a schrader valve. Pump the can you just made up to your tire pressure spec. Do a relearn on the sensors... I use the GM handheld learn tool (there might be other ways too). Throw it in with your spare tire and those sensors will be sending the proper psi to the tpm module.
Old 02-11-2012, 02:05 PM
  #58
apicia's Avatar
They don't have to spin or have a certain RPM?
Old 02-12-2012, 11:48 AM
  #59
guitarenvy's Avatar
When stationary, the sensors sample the pressure every 30 seconds but do not transmit an update unless there is a change in pressure inside that canister.
Normally when the sensors are installed in the tires, they will transmit pressure readings every 60 seconds when the vehicle is moving. The internal accelerometers see the vehicle is moving and tell the receiver to enter rolling mode. Im pretty confident that the cobalt does not compare vehicle speed with the state of the TPM system (stationary/rolling) so it doesnt care if the sensors ever "roll".
Old 01-20-2017, 07:54 AM
  #60
Tom Hag's Avatar
Originally Posted by cereal83
Doesn't the wheel have to rotate for the sensors to work?
THEY RESET AT 20MPH, BUT MOST SHOPS HAVE A TOOL TO RESET AT A STAND STILL. SO YOU CAN GET PIC PIPE WITH 2 CONE ENDS AND A PRESSURE INLET AND PVC GLUE. GLUE ONE CONE ON AND HAVE A RAG, DRILL HOLE BIG ENOUGH FOR PRESSURE VALVE. THEN GET TPMS RESET, PUT THEM AND RAG IN TUBE and GLUE OTHER SIDE ON AND PUT PROPER AIR IN TUBE. THEN PUT IN TRUCK AND BAM. DONE
Old 01-20-2017, 10:26 AM
  #61
double clutch's Avatar
^holy caps lock batman
Old 01-20-2017, 10:34 AM
  #62
SS_MuNky's Avatar
Holy old thread Batman!!
I'll never get why people feel the need to make their first post the bumping of a very old thread
toysareforboys
11-17-2015 05:22 AM
Tdubbs
10-13-2015 02:31 PM
royce777
09-28-2015 07:11 AM
08BlackSS/TC
12-30-2006 02:24 AM
Jmc007
10-20-2005 12:18 PM
Quick Reply: How to disable TPMS?
