Light Throttle Stumbling
#51
Intake solenoid: 12646783
Exhaust solenoid: 12646784
#53
People kept bringing up sensors or perhaps confusing them with sensors. These are not sensors. These solenoids control the oil flow from the head to the phasers. If people are wanting to know where the cam sensors are located for some reason though, they are on the driver side of the head, near each cam end.
#56
I'm having major issues with this. My car will stumble so bad sometimes that I can press the throttle pretty hard and it will just keep stumbling and not accelerate.
I did a boost leak test last weekend to 25 psi and I couldn't hear any sort of hissing except coming from that black hose going to the intake manifold that's about 3/4" in diameter.
I'm throwing P0101, P0106, and P0236 codes which are for the MAF and both TMAP sensors.
Is it possible this is occuring because of the fuel filter 'sock' needing to be changed? I still don't know how you're actually supposed to change it though. If I knew I would totally change it.
#57
I just got a P0011 Code pulled today that said: Camshaft Position/Timing Over Advanced, My Tuner says that thier the Solenoids that you speak of(I think lol), The Symptoms are: Cold Start Stumbling/Hard Starting when Cold, Running Crappy, Just seems like something is off. Hopefully these Solenoids fix the issue im having .
#59
#60
same thing that's happening to my '08 tc(stage2) right now, don't now what to do...gone to the dealership few times,change the fuel injector, sensors..they can't seem to pin point the problem..now it's worse, stalled me on second gear..doing this crazy sound like "toooododododo",,scary..need help?
#61
Yeah well I just got my car back from the dealership and they replaced the Intake side Camshaft Solenoids under my powertrain warranty, So lets see if that cures the symptoms that I was having. I'll keep you guys updated!
#62
#64
Yep, I count YOU as my Tuner too.....Even though we havent met yet, I consider you more of my Tuner than my actual Tuner, If that makes sense, lol. We spend more time talking then I do with my actual Tuner, So its like your Both my Tuner but I consider you as my Go to guy for any issue/questions, Just wish you lived closer to me thats all and I would use you and only you.
#65
I keed I keed
#66
#67
Sarah, GM Customer Service
#68
, It is Complicated, John's one of the Best Tuners out there and he has spent a lot of his spare time talking to me and helping me through issue after issue. He genuinley cares and isnt just concerned about taking your money. Shi* I havent given him a dime and he's spent more time talking with me and helping me out then most Tuners would, Thats Troof lol. Thanks for all your help brotha!
#69
Just an update on this for anybody who's had this happen or perhaps enjoys puzzles... lol
The stumble is still happening only at cruise throttle. It idles, decelerates, and accelerates perfect.
The car has:
- New crank sensor
- New cam position sensors
- New phaser solenoids (the ones in the head, not the phaser hubs themselves)
- New upstream/wideband O2 sensor
- New injectors/rail/pressure sensor
- Cleaned MAF and MAPs
- New stock/gapped spark plugs
- Heck... a whole new six speed transmission, clutch, flywheel, and axle since last time... lol
No misfires or knock, does it on both the Trifecta flash and stock flash, and even with the MAF disconnected (ruled out MAF issue or intake issue). The spark advance fluctuates when the stumble is occurring. Checked the throttle pedal position sensor, throttle position sensor, cam phasing, fuel pressure, coil packs, etc. There appears to be no other cause-effect signs on logs I've done for myself or for Trifecta.
It only does it at part throttle, and seems to do it less or not as bad when the car's heavy (like more people in the car and/or full tank of gas), and more when the car's lighter (just me and/or a light tank of gas).
This means it's probably not airflow metering related, not fueling related, not spark related, not tune related, not sensor electrical related,... what else is there it could be that's causing this? At this point it's almost like it could be suspension related due to the weight and throttle things changing it, and the only suspension thing I can think I changed around the general time this started popping up was going to the Powell CABs. Could it be that this is a case of the ECU being too smart for its own good, picking up on the car maybe moving around in the solid/stiffer CABs, and trying to quickly adjust spark advance?
I'm stumped. I feel like I've ruled out, checked, or replaced just about everything that traditionally causes this kind of thing.
The car has:
- New crank sensor
#71
Mine will stumble right after cat warm up mode at idle. Had a few misfire cels at one point and then a flashing cel at WOT in third. Dealer told me it was the valves and that because the car was outside and cold that it was the problem. I cleaned the valves and the car now sits in a heated garage. The third gear misfire is gone which is not surprising (the valves were pretty nasty) but the post cat warmup idle stumble remains.
Gets to about 1000k rpm and starts doing it. Not every time I start the car but probably about a third of the time.
I did some of the same logging as you but I didn't look at the cam phaser solenoids, just timing, afr, and knock. Didn't see anyone weird. No boost/vacuum leaks, gms1 tune with MAPs I crimped/plugged myself. Stock everything.
#73
Update on this:
I had started getting some rattles when going over small bumps, and after some inspection I found that the passenger suspension spring had relaxed a bit and the rear control arm bushing bolt seemed a bit loose when I checked them. I tightened up and preloaded the coilover springs 5mm, and re-tightened the rear CAB bolts to spec, and not only have the rattles gone away, but the spark timing jumping / car bucking has also.
What may have been happening was that the CAB bolt(s) were just loose enough for the control arm to move around too much in the subframe cradle it sits in, and the movement slack caused a back and forth jerking between between the control arm (basically the car's wheel) and rest of the car. This would explain how the car would do it's bucking/jerking/spark timing jumping thing independent of any tune flash or general powertrain changes, and wouldn't do it when accelerating or would do it less when the car was loaded down with people or gas.
I've tested it out for a few days now, with no spark timing jumps when it would normally happen every few seconds, so it appears it may be fixed now. I'll post up again if that's not the case, but this appears to be closed now. So if you have similar issues, check that your rear control arm bolts are tightened to spec. It also helped first gear on-off throttle transition to be smoother.
XStylus (12-30-2016)
