Low ash oil recommendations
Old 05-24-2016, 12:41 PM
axmonkey's Avatar
I'm trying to find oil with low ash content.
From what I am seeing Mobile 1 ESP 5w30 should fit the bill. Am I missing anything?
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-esp
I've seen mention of European versions. This AMSOIL ESP seems to fit that but doesn't specifically call out low ash.
AMSOIL European Car Formula 5W-30 Improved ESP Synthetic Motor Oil
Mr. Powell recommends "low ash" oil but I haven't seen him recommend anything specific, I like to know what he's using.
I'm pulling the intake this summer and walnut blasting, and going to pick up Mr. Powell's PCV system. I've been keeping the RPM's up and using 93 octane to minimize the coking but I want to make sure I'm running the right oil too.
Old 05-24-2016, 01:33 PM
cluelessk's Avatar
Don't worry about it.
Coking will happen no matter what.
Old 05-24-2016, 02:55 PM
umrdyldo's Avatar
Cool an oil discussion. ESP is great if you can find it.
Otherwise Mobil 1 Extended Performance is good enough.
As said you won't prevent coking.
Old 05-25-2016, 03:35 PM
califcarm's Avatar
I think you can be sure you have the right oil properties (low ash, and all others required for the LNF) if you use one with GM4718M approval. It is on normal Mobil1 5w-30 that can be had cheap at Walmart (it's on the back label).
The ESP does not have that approval, so while I agree that I think it is low ash, I am not sure it meets the other requirements.
https://mobiloil.com/en/motor-oils/m.../mobil-1#5W-30
Old 05-26-2016, 03:03 PM
axmonkey's Avatar
Crap, nice catch on the GM spec...
Old 05-26-2016, 06:44 PM
cluelessk's Avatar
GM4718M is about heat management without an oil cooler.
Many oils meet the requirement but don't have official accreditation due to the costs involved for the relatively few cars that require it.
Old 05-27-2016, 09:02 AM
califcarm's Avatar
Agreed. I have always preferred M1 0w-40 for my other 2 liter turbo applications as it has much better viscosity at higher temps and has a better base stock oil than the other "standard" M1 oils like the 5w-30 that the LNF calls for. But those were all port injected so low ash was not important.
For the LNF, I am sure there are a long list of oils that would work fine as long as they are low ash (even if they don't have the GM cert). But I will stick to M1 5w-30 because I just daily drive my car. But if I did track it, I would probably be looking at a better oil for that purpose.
Old 05-27-2016, 09:15 AM
umrdyldo's Avatar
I thought i remember specifically Powell telling us that the Mobil 1 Extended Performance had the best additive pack. And yes you can run 0w30 without issue for a little better gas mileage.
Powell recommended changing at no later than 30% on the DIC as well.
2000Firehawk
05-25-2016 07:25 PM
tomj77
05-23-2016 08:04 PM
austin8898
05-23-2016 02:31 AM
metroplex
05-21-2016 06:50 PM
Dougsterbob
05-20-2016 12:14 AM
Quick Reply: Low ash oil recommendations
