Offical: Porous Block Problem Thread
#254
alchargo. He kept the car and got a hold of an LHU to swap into it. Swap is done, cars making 25psi. His brakes are like new. Hes really happy with the car now.
i have an 09 SS sedan for 95,500 miles now and I have yet to see signs and symptoms of porus block yet. I noticed my coolant dropped last year maybe a cup (only a cup), but nothing else is showing any signs. I am thinking not all LNF engines went through this issue or at least I hope so.
#257
I surprised you got yours to leak when cold. Must've been a really bad crack. Mine didn't leak when cold (I filled the water jacket after pulling the block to try to find the crack).
But yes, mine did the same thing. I'm not sure how long mine went from a skosh low to peed into the crankcase, but it was a while between.
#262
Honestly I agree with these guys. I wouldn't worry just yet. A lot of my issues were probably our family curse with GM. None of us have ever had a GM vehicle of any type that didn't suffer from some kind of catastrophic failure lol. But I'll be the first to admit I beat on my car more than I should've & I'm sure that had something to do with it lol. I'm the worst about not being able to say no to a street challenge
#268
I sure hope this isn't the case but I think I may be having the same issue with the LHU. Or maybe I'm just paranoid? I went to check the oil today & the level is higher than it was the last time I checked it (up past full slightly) & the coolant is slightly lower than I remember it sitting.
#270
Yeah I'm pretty sure you're right. I think it's just paranoia. I checked them both again & everything seems fine. Except now I've got a knock sensor code popping up. I think I got a bad tank of gas though because it happened right after filling up. I'm really not sure how much I trust this car anymore.
