Random Misfires PLEASE HELP
Ok. So in the last year and a half this is what I've been through. New zzp catted downpipe, new k&n short ram intake, injen charge pipe. No issues. Then I got a dyno tune last summer. Soon after started getting cel lights for no apparent reason that would come on and off from time to time. 6 months ago I started getting random misfires and the problem persisted. I was getting codes for sensor 1 low bank, maf sensor, misfires in cylinder 1, 2 and random cylinders. 3 months later my turbo died. Replaced the turbo myself and took it to the dealer to confirm I put it on right, they confirmed it was done correctly, yet didn't even realize that I STILL had misfires and gave me a bill of $400. I've replaced coils and plugs since and still hasn't seemed to make much of a difference. I can drive my car and it's fine and then other times it misses so bad it won't let me accelerate. I'm so confused and NOBODY, not the dealer or any of the several mechanics I know have any idea. Please, if you've had similar problems or have any ideas please help me. People keep suggesting injectors, but on a car with less than 65, 000 miles, I find it about as likely that all four injectors are bad as I did think all four coils were bad. Thanks, Brian
Oh, before the turbo went out I replaced the MAF sensor also. And lately the codes I'm getting are basically the same. I'm getting maf, sensor 1 low bank, all cylinders are misfiring, and baro sensor
ok so even though I thought I felt misfires...it's not giving misfire codes. But since I've changed the coils/ plugs, I haven't gotten any misfire codes, yet new codes. Here's what my scanner shows.
misfire mon ok
fuel monitor ok
comp component ok
catalyst component ok
htd catalyst n/a
evap system mon inc
sec air system n/a
a/c refrig mon n/a
oxygen sensor ok
oxygen sensor htr ok
EGR/VVT sys mon n/a
P0451 ENG
evaporative emission system pressure sensor/switch
range/performance
current history MIL
P013E ENG
sensor delayed response - rich to lean (bank 1 sensor 2)
current
P0101 ENG
mass or volume air flow A circuit
range/performance
intermittent
P0106 ENG
manifold absolute pressure/barometric pressure sensor
range/performance
history MIL
P0106 MOD $00
range/performance
confirmed
P0451 MOD $00
range/performance
confirmed
P013E MOD $00
pending
P0451 MOD $00
range/performance
pending
P0101
range/performance
pending
misfire mon ok
fuel monitor ok
comp component ok
htd catalyst n/a
evap system mon inc
sec air system n/a
a/c refrig mon n/a
oxygen sensor ok
EGR/VVT sys mon n/a
P0451 ENG
range/performance
current history MIL
P013E ENG
current
P0101 ENG
range/performance
intermittent
P0106 ENG
range/performance
history MIL
P0106 MOD $00
range/performance
confirmed
P0451 MOD $00
range/performance
confirmed
P013E MOD $00
pending
P0451 MOD $00
range/performance
pending
P0101
range/performance
pending
I would check the evap purge valve for failure first. That might explain your evap codes.
Disconnected Evap Purge Solenoid = Very Happy LNF - Cobalt SS Network
Here's how to test it.
Here is the link on how to do a boost leak test.
2.0 LNF Engine Boost leak test a stock SS LNF. - Cobalt SS Network
Ok, so are you saying i should just buy a new evap solenoid? How do I bypass the boost surge tank and what would that do? And what is a borescope? I'm guessing it checks the valves? But how do valves go bad intermittently?
There is a vacuum/surge tank right under the intake manifold on the passenger side. Sometimes that tank gets cracked and causes boost leaks. Which would give you a P0101 possibly. Just trying to narrow down your issue at this point. Boost leak is usually the answer.
Do you have a way to look at your fuel trims? Torque app or HPTuners? trying to see how close your tune is.
oh ok, yeah i replaced that and all the vacuum lines to it when I changed the turbo. I'm just really blown by this car. I've always treated this car with the best care and it has just sucked the whole time I've had it. I really appreciate all your suggestions/ help so far. I just don't understand these turbo cars, which is the reason for all the questions. I'm spent, I really am.
Again, I don't understand. I have a scan tool that I can erase codes with, if that's what you mean. And then I guess I buy this robot check do hicky and run it to see what it says and then get back to you?
Sorry I didn't respond sooner.
The previous link I sent is to a device that plugs into your OB2 port where a normal scanner goes. It's bluetooth and it syncs to your Android phone or tablet. You then get an app called Torque. The app allows you to monitor all sensors on the car. So not only can you check and clear codes with it, but you can see everything your car is doing.
misfire mon ok
fuel monitor ok
comp component ok
htd catalyst n/a
evap system mon inc
sec air system n/a
a/c refrig mon n/a
oxygen sensor ok
EGR/VVT sys mon n/a
P0451 ENG
range/performance
current history MIL
P013E ENG
current
P0101 ENG
range/performance
intermittent
P0106 ENG
range/performance
history MIL
P0106 MOD $00
range/performance
confirmed
P0451 MOD $00
range/performance
confirmed
P013E MOD $00
pending
P0451 MOD $00
range/performance
pending
P0101
range/performance
pending
misfire mon ok
fuel monitor ok
comp component ok
htd catalyst n/a
evap system mon inc
sec air system n/a
a/c refrig mon n/a
oxygen sensor ok
EGR/VVT sys mon n/a
P0451 ENG
range/performance
current history MIL
P013E ENG
current
P0101 ENG
range/performance
intermittent
P0106 ENG
range/performance
history MIL
P0106 MOD $00
range/performance
confirmed
P0451 MOD $00
range/performance
confirmed
P013E MOD $00
pending
P0451 MOD $00
range/performance
pending
P0101
range/performance
pending
If I had a boost leak, how would it be an intermittent problem? Just wondering. Maybe I should explain these "what feel like misfires a little better". I'll be driving and then randomly, my car will stutter/stumble on acceleration. Almost like the car is being shaken. Usually it takes 30 minutes or so for the problem to start, the other day i got two minutes away from home and it was stumbling so bad that it wouldn't even let me accelerate. Turned around and it rode shitty the whole way home. Until I got on the road to my house. Put it in second and it would hardly accelerate, put it in third and it accelerated like a bat out of hell like there was nothing wrong with it. So my question is, if this was/ is a boost leak, how would it be leaking intermittently?
Yeah well I guess make you need to get a way to log it. I'm guessing you have some tuning issues that could be related.
Cheapest option
Robot Check
Plus the Torque App for Android. That will help you log and erase codes. I'm guessing your fuel trims are bad.
Cheapest option
Robot Check
