Rear Brake Caliper Piston
09 Cobalt SS. Replacing rear pads and rotors. When you guys screw the piston back into the calipers do you clamp off the rubber brake line & crack the bleeder screw or is it ok to just screw the piston back in as is with the fluid going back into the master cylinder ?
If I don't have to crack the bleeder screw I'd rather not because of the chance of snapping them.
Thanks.
Thanks.
You can supposedly ruin the seals in the master cylinder. I'll admit I've done it without opening the bleeders but most experienced techs I've asked have said to open the bleeder. Don't open the master cylinder cap unless you want to contaminate the fluid.
So as long as I only screw the piston back in, with the bleeder open and don't touch the pedal or anything else, I won't have to bleed the system ?
Nope. Although it wouldn't hurt to put new fluid in the reservoir and bleed all 4 brakes + clutch, especially if the fluid is black. The proper order is RR, LF, LR, RF, Clutch.
Pure laziness for me. I have a Motive power bleeder, but as I would go from track to street pads, I just needed to back the piston in a little. It really is a good idea to open the bleeder. Maybe I was lucky, because I'd have clean fluid when the track pads went on and so the fluid was still pretty clean when the street pads went back on a week later.
Could probably make an adapter for cheaper with an extra cap, but this is the easiest solution.
I'm not sure about using with the clutch.
This bleeder allowed me to do the entire brake job with no help and flush the whole system with new fluid.
You can use a power bleeder on a clutch, but you must use LOW pressure. I'd start with 5 psi and be patient. With too much pressure you could pop the slave cylinder, which is attached to the throwout bearing, which is inside the bell housing and a huge pain to swap out.
You can find an adapter that goes on a socket wrench at a local auto store, should cost you a couple bucks or you can opt for a nicer kit (caliper wind back tool kits) which run around $30-40.
