snow tires and rims size?
Old 08-23-2009, 07:08 PM
Cobalt_Daddy's Avatar
Anyone know what size snow tires and rims are required for my 2009 cobalt ss/tc? apparently you need a special sized steel rim to fit the brakes on the front.
i don't want to drive it in the winter much but it is Canada and i may not have a choice one day so i want to be prepared...
Cobalt_Daddy
2009 Cobalt SS/TC
Old 08-24-2009, 01:50 AM
importkiller's Avatar
It is my understanding that there are no steel wheels that will work on our cars due to the brembo calipers. The smallest you can go is 17 inch alloy, and that is if you cant find a wheel that clears the caliper. the problem is not the disk diameter it is how far the caliper sticks out.
OH
BTW...if you use search you will find about 100+ posts about this issue.
Old 08-24-2009, 01:56 AM
aterminatorz's Avatar
I put Michelin Pilot Alpin PA3 tires on my stock wheels and they worked great in the winter. I had all seasons and they were terrible when the temperatures were freezing, so I exchanged them for winters. With all seasons I was stuck in snow often and could not even get up my shoveled driveway!
Old 08-24-2009, 02:45 AM
i did alot of searches on the topic but majority of them were in reference to the older model cobalt SS's with smaller brakes and rims. not sure what to do now... maybe just park it for the winter. :/ i put aside $1,500 for winter tires and rims hope there is something out there that will work.
Old 08-24-2009, 06:31 AM
Sweetsandman's Avatar
I will be getting a set of wheels off of a SS/NA (17"...the ones that fit over our brakes) and putting some Blizzaks on them for winter use. It's a relatively cheap combo and will certainly rock in the winter.
Old 08-24-2009, 07:15 AM
jb09ss's Avatar
I used those wheels last winter
They are distributed by macpek, a heavy truck part distributor. I think they only have distributors in the province of Quebec, but they are 170$ a wheel and shipping would probably be not too bad. Part number AGM753A. They are also a quite heavy and strong wheel, which is good for our pothole infested winter roads.
Old 08-24-2009, 11:58 AM
thanks i'll look into that
so the old 17" or 18" rims on the 07 SS and down will fit our brakes? i thought the brembo system was new for 08-09? can anyone verify the smallest size of rims that can be used as winter rims? I've been on sites that have old cobalt SS/SC 16" winter rims but i really doubt they would fit my 09.
Last edited by Cobalt_Daddy; 08-24-2009 at 12:05 PM. Reason: Automerged Doublepost
Old 08-24-2009, 01:13 PM
jb09ss's Avatar
17'' is the smallest that will fit, some people will add a 3mm spacer with the 17 ss wheels for clearance.
Old 08-25-2009, 06:03 PM
J.U. 996SPS's Avatar
I bought the MSR 045's on the last spring sale....using my stock wheels and performance snow tires
bigdeertz
11-17-2016 09:41 AM
10-13-2015 09:32 PM
DANRICKARD
10-01-2015 12:08 AM
nathan112i
09-30-2015 07:12 PM
09-26-2015 06:44 PM
Quick Reply: snow tires and rims size?
