Weird shit happened today
Old 04-23-2014, 09:22 PM
cfsnipers's Avatar
Weird **** happened today
2010 Cobalt ss hptuned started backfiring like a **** today. Idle speed decided to jump to 2000rpm for no reason whatsoever, throttle had shitty response but full power was still there. Full boost and zero knock. I pulled over at a gas station and disconnected the battery for 10 minutes, hooked it back up and now its running perfectly once again.
Anyone else ever heard of this anomaly before
Old 04-23-2014, 09:24 PM
yeah thats the name of the game lol wierd ****
Old 04-23-2014, 09:29 PM
cfsnipers's Avatar
Friggin GM
Old 04-23-2014, 09:40 PM
LNFTX's Avatar
Originally Posted by cfsnipers
Friggin GM
Dont frigg gm for a car you modified
With no codes or log itl be pretty tough to tell but you proly wanna start to check the stuff that usually goes wrong maf map boost/vac leak
Bone stock only weird unexplainable issue ive had is a random bucking the car does very rarely at low rpm cruising
Old 04-23-2014, 09:54 PM
ItalianJoe1's Avatar
Sounds like a possible idle air control/TB issue, have you ever cleaned it? It sounds similar to a fault my old car had, if I sat idling for a long time the car would basically go into reduced power mode when you tried to touch the throttle again to take off. Turning the car off for a little bit would clear it up, or if you tapped the gas every now and then when idling it wouldn't do it either, had to sit at a dead idle for a couple minutes straight.
Never figured it out, just dealt with it Was impossible to track down what was causing it, even logs showed it pretty much acting normal until it went into retard mode, at which point everything was off-kilter.
Old 04-24-2014, 05:55 PM
m33pm33p's Avatar
That's also your fault, and not gm's.
Old 04-24-2014, 06:35 PM
LNFTX's Avatar
Where in that quote am I blaming gm
Point was with a stock car I very rarely have any issues or reasons to blame gm
Old 04-24-2014, 08:33 PM
cfsnipers's Avatar
Well it runs fine now but some ******* ran into me today and caused 1k worth of damage to my rear bumper. Got all his info tho! Won't cost me a cent.
Old 04-24-2014, 10:03 PM
Piston3's Avatar
Take it to a dealership and get them to price match OEM parts to the aftermarket prices that are going to be on the insurance company's estimate.
Old 05-01-2014, 09:32 AM
r3v07ut10n's Avatar
man you got back luck
Old 05-01-2014, 10:50 AM
cfsnipers's Avatar
^I know man. It'll be all fixed up and a brand new KY stage 3 installed when I get back from training in 7 weeks.^
Fearedbynone
04-14-2016 03:25 AM
biniecki
10-25-2015 02:23 PM
dennis69
10-20-2015 04:49 PM
no_ss
10-18-2015 11:58 PM
Quick Reply: Weird shit happened today
