6258 Sky Project Spool
#54
Atm I have no clue, all I do is dd the car if it happens to fail on me so be it plus i dont get on the boost that often maybe 1 or 2 times a week at the most. And I need to see the smoke myself my wife said black but it could be blue she was following me on her car and told me the car had black smoke when I accelerated
#55
Double check the color of the smoke.
Black smoke is not really a big deal while it's getting dialed in if you aren't missing. It should show up in the logs as well.
I have a lot of black smoke.
Do you have a video of the noise
#61
If its not during wot and you are sure its black then the problem should be really visible in the logs.
Maybe there is a injector sticking or really bad missfire.
I was having misses at max boost, gaped the plugs to 31 today no more missfire.
Also how much kmock are you getting
#63
Setup your scanner like so and see what is knocking.
It will help you diagnose the issue.
then try to see if its real knock, take timing off, if you are brave add timing to see if it get worse.
also try a different plug gap. Try 32 or 30
Mine only likes 32 for some reason.
#65
Mine as well but I made a few changes to show more info.
I have a data logger in my cars radio that logs the same thing as those tables. Maybe something you may want to look into once you get yours dialed in.
#67
So Carlos fixed all of his issues and she's running great!! I'm gonna pull a bit of boost it was a steady 30psi and on 93 that's a bit much I'd rather get some timing in her
#68
We swapped to E47 and cranked the spool up and lost a ton of fuel pressure so we're going back to a HPFP friendly tune. I'm waiting for another guy to install his lobe then I'm gonna do that LNF fuel thread I have a lot to share
#70
Originally Posted by KMO43
The cam is really easy to do just remember to turn the engine over by hand a couple times to help the tensioner get the slack out
#72
Stumpy
51
04-25-2016 08:10 PM
