Air/Fuel Ratio for LNF??
Is that sarcastic? Cause sometimes even a woman needs her ass kicked
I need to study the DashHawk more.
UPDATE
I figured out the DashHawk. The factory wideband PID is Wideband 1 and works perfectly on the DashHawk. I am very happy to see this work. So I setup mine to display Commanded and Actual right next to each other.
UPDATE
Well I have been running mine with a AFR of 12.8 for over 6 months and constantly put it into boost with no problems. This is a direct injection which requires miniscule amounts of fuel as compared to a regular engine. I f you look at the tail pipe on any of the LNF cars you will see that its still running rich enough to make black smoke.
I was unaware about my LNF having a factory wideband but its alright though. I checked to sensor on the AEM today and compared it to the factorys wideband through my aeroforces. The AEM is much more accurate than it was yesterday. I'm guessing that the O2 sensor wasnt tight enough on the downpipe. I noticed that the factory wideband isnt as active as the AEM. When it comes to full throttle the AEM picks up much quicker than factory does so I'm actually pretty glad I bought the AEM. I appreciate the help from everyone. At full throttle I sit at about a 12.3 and at idle anywhere from 14.5 to 15.7(this is the AEM having its bouncing around fun .
"My car is making a lot of soot, is this normal?
Yes, like the ticking the soot is an unfortunate side effect of running a SIDI engine. Using a metal polish or long lasting auto wax on the tail pipe will help make cleaning easier."
https://www.cobaltss.net/forums/show...85&postcount=2
Best of luck to you.
If you're interested, here's the cosmetic workaround:
UPDATE
UPDATE
#37
Why is your car so rich stock? Everyone who has ever dynoed or tuned their car has seen that it starts at 15:1 in the lower revs and goes to 14:1 then finally to 13.4 at 5500 rpms. Ask Area 47 and Psychostevo. I think your scanner is not reading properly or something because you are the only one who has ever posted an A/F that rich stock. IDK. Ask anyone was has seen the stock A/F while dynoing the TC. It is way leaner than your tuned A/F.
#41
#42
Richer mixture = more gas used = worse gas mileage
DI also allows for safe leaner mixtures than previously capable. I think that's what he's saying.
On the other subject, I'm pretty sure it's normal for tunes to go rich under acceleration. In DI it helps keep engine temps down while also protecting against pre-ignition/detonation. Also, when you get off the throttle and certain conditions are met, it'll go lean or even cutoff fuel to save gas while coasting. Idle seems to be around the 14.7 stoic ratio, but my guage jumps around +-0.5 or so.
To the guy with the rediculously rich mixture: Try disconnecting the battery for a while and reconnecting to reset the ECU. Either that or take another reading after a few days. Maybe it's trying to adapt to something going on with the car.
#43
I'm just trying to keep up here. I still think is some confusion on the threads as to what number value is rich and what is lean. If you're at wide-open throttle, I'm pretty sure the last thing on your mind is fuel economy, UNLESS you're in an endurance race. Keeping the fuel mixture rich, as you said, would aid in combustion chamber cooling and prevention of predetonation.
#44
#46
Turbo06Sedan is right.
A 14.7 Air-to-Fuel Ratio is the correct ratio for all of the air to react with all the the fuel in the combustion chamber... or anywhere for that matter.
If you are higher than that (>14.7 A/F Ratio), then you have a leaner mixture. This causes a hotter burn and better fuel mileage, but the heat from the hotter burn can cause damage to the engine if it is not designed for the hotter temperatures.
If you are running lower than that (<14.7 A/F Ratio) then you have a richer mixture. This causes a cooler burn and worse fuel mileage, but the cooling action allows for protection of the engine during high throttle/boost/load applications when pre-ignition/detonation/"knock" have the highest probability of occuring. The side effects of a rich mixture would be getting worse gas mileage and having extra black smoke come out the exhaust. You would also notice a blackening of the exhaust/tip and perhaps rear bumper.
Now knowing that, most stock tunes are designed to run about 14.7 when at idle, lower than 14.7 (rich) for hard acceleration, and slightly higher than 14.7 (lean) for light throttle. For those that have a wideband/factory RPD you can view the AFR and watch your car change the ratio under different circumstances. To further save fuel, you vehicle has a fuel cutoff that engages during coasting/no throttle at speed when in gear (so you're not "sitting" on the idler). When this happens, you will notice that your AFR will peg at 18+ and your engine is essentially windmilling.
Cool, huh?
Cool, huh?
#48
#50
