Aluminum flywheel = CEL p0300 p0301 p0302? - Cobalt SS Network
Technical Discussions ONLY!
LinkBack Thread Tools Search this Thread
Old 06-12-2011, 01:58 PM   #1
Just as the thread states. I know it may sound stupid that a flywheel can cause a CEL but just hear me out.
I recently installed an aluminum flywheel and a clutchmasters stage 4 in my car. I have only 40 miles on the car and anytime I come to a stop for 30 seconds to 1 minute the car is flashing the check engine light. It runs completely fine for normal driving with no audible misfires or sputtering. I have not beat on the car with the new clutch in it so I can't tell you how it's doing at WOT.
I threw the scanner on there and p0300, p0301, and p0302 all show up. I've read that because the flywheel revs faster the computer thinks it's a misfire or knocking? I reset the codes and let the car idle in the driveway for a minute and they come right back. I know this is very common when Subaru's put in a light flywheel but I haven't heard anything for the Cobalt's yet.
Andrew
slowstang is offline   Reply With Quote
Old 06-13-2011, 06:14 AM   #2
Images: 3
i had the same problem untill i put a new battery in. before that it would just spit and sputter at ideal. Put the new battery in and well off. I thought i was my flywheel to. hope this helps.
A.J. is offline   Reply With Quote
Old 06-13-2011, 09:06 AM   #3
Iam Broke's Avatar
Images: 4
Never had that with the SPEC LW FW but it did log a few more misfires than the stock FW. If you have access to HPTuners, raise the idle to 900 rpm and see if that helps.
Iam Broke is offline   Reply With Quote
Old 06-13-2011, 03:52 PM   #4
i"ve been having the same problem with my excedy. only on the e tune, on 93 it's fine
Yellow09LNF is offline   Reply With Quote
Old 06-13-2011, 06:05 PM   #5
I swapped the coils around to see if the CEL would follow the coils and it doesn't.
Might not be a bad idea to put a meter on the car and see what voltage it's getting. It is over 3 years old now.
Quote:
Iam Broke - Never had that with the SPEC LW FW but it did log a few more misfires than the stock FW. If you have access to HPTuners, raise the idle to 900 rpm and see if that helps.
Yes I plan on raising it to 900 or so. It should making taking off alittle easier too.
Old 06-14-2011, 06:25 AM   #6
Just installed a clutch master stage 3 put in 1000 miles tuned for e85 car ran good, raced a couple of people then all of a sudden started getting a flashing cel put the scanner was getting those same codes. Cleared computer and it went away hasn't came back yet.
20redline is offline   Reply With Quote
Old 06-29-2011, 05:54 PM   #7
Fast forward 2 weeks and added 300 miles on the car. After a long 100 mile drive to the beach it just stopped flashing the CEL all together. No CEL or anything now...weird.
Old 06-29-2011, 06:34 PM   #8
Images: 6
If a clutch was installed and ect. look into the wiring, check your grounds i can almost guarentee your issue lies there.....!!!!!
Chevycobaltss3 is offline   Reply With Quote
Old 06-29-2011, 06:35 PM   #9
Images: 6
Ure issue lies within the tune or plugs.... Id check gappage of the plugs and see if lowering the gap helps. If not check your tune. 3 coils do not go out instantly at the same time like that!
Old 06-30-2011, 07:26 PM   #10
Quote:
It can't be the tune because that's been on there for 36,000 miles and 2.5 years. The only changes to the tune have been WOT tables. I've had the NGK plugs on there for about 10k miles now. It's possible it could be the plugs but why all of a sudden was it misfiring after the clutch install and cleared up with me not touching the car besides a coil rotation.
Old 06-30-2011, 08:14 PM   #11
Images: 75
I have a Spec 3+ clutch and Spec aluminum fw, I don't get any misfires.
HHRSSouth is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
No power and a flutter sound turbochargedss2012 2.0L LNF Performance Tech 7 03-20-2016 01:30 AM
For Sale Seat headrest braces cavfiredesire Parts 1 10-03-2015 09:02 PM
Nathan112i FCOTM submission thread nathan112i Featured Car Showcase 41 09-30-2015 08:12 PM
CEL for Air/Fuel ratio DocSvensk 2.0L LNF Performance Tech 7 09-27-2015 03:24 PM
ZZP OEM Flywheel jas09ss Drivetrain 2 09-26-2015 02:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
