Bullseye Power Batmowheel for Ko4
Old 12-13-2011, 02:14 AM
  #226
Thread Killer
FrossB's Avatar
TR8 is what i have.
Old 12-13-2011, 02:15 AM
  #227
Samy's Avatar
Sub'd for results, this could be an awesome addition to the lnf.
Old 12-13-2011, 02:27 AM
  #228
MajorCB's Avatar
how was the fitment of that TR8... did you do it yourself? or have someone do it....
Old 12-13-2011, 03:35 AM
  #229
EXsoccer1921's Avatar
Originally Posted by MajorCB
I agree with you... I'm still deciding what IC to purchase though... I hear the latest ZZP design is good... but I really just want one that will be able to use the stock piping... again, my goal is to continue to look as stock as possible.. so I'm looking for that design that will best fit my requirements... any ideas?
the new zzp design for the lnf intercooler is actually shorter in over all height so it has no ground clearance issues but still yeilds the same drop in IATs over stock as the first one did.
Old 12-13-2011, 03:36 AM
  #230
wheel should be done later this week or monday/tuesday next week according to david. i don't know if they'll flow it out their turbo "dyno" or not though.
Old 12-13-2011, 04:15 AM
  #231
Samy's Avatar
Are they planning on making a flow chart for it? I know its a pain in the ass, but it would be the best way to show real world flow.
Old 12-13-2011, 05:17 AM
  #232
MajorCB's Avatar
this sounds like a good thing...
Old 12-13-2011, 02:45 PM
  #233
not sure about producing a chart but yes it will be flow tested.
Old 12-13-2011, 02:54 PM
  #234
RooTBeeR's Avatar
that last thing the ko4 needs is faster spool haha but still curious how much faster it will spool in comparison
Old 12-13-2011, 04:36 PM
  #235
Samy's Avatar
I cant see it spooling much faster. But flowing higher volumes of air seems very probable.
Old 12-13-2011, 04:46 PM
  #236
JacBlackSS/TC's Avatar
treadstone makes a kit for both the cobalt you have to look under intercooler kits but you can pick your core size, i have the tr10 and it has no fit issues.
but i am in the downtown area for school
Old 12-13-2011, 04:47 PM
  #237
RooTBeeR's Avatar
indeed, hold a higher psi out farther
Old 12-13-2011, 06:28 PM
  #238
40rty's Avatar
Doesn't the wheel need to be physically bigger to flow more air?
Old 12-13-2011, 06:32 PM
  #239
Samy's Avatar
No. Wheel aerodynamics and weight make a huge difference in airflow.
Old 12-13-2011, 06:42 PM
  #240
jonnymerk's Avatar
silly question, but could I send my blown 60trim knock off turbo to these guys and have them rebuild it plus add their wheels?
Old 12-13-2011, 07:57 PM
  #241
BEP has designed these wheels to have more surface area along with being lighter, anywhere from 10-20grams, than the wheel theyre replacing. the only wheel they've produced that wasn't lighter than the wheel it was replacing was because the wheel it replaced was a 10blade and the batmo and billets are 6blade. this wheel still flew more air than the one it replaced.
what "60 trim" are you using, size, brand, journal or bb??
Old 12-14-2011, 04:58 PM
  #242
jonnymerk's Avatar
ughh it's the ebay turbo I think. It's layin in my garage atm.
A/R .70/.63
Not 100% on BB or Journal bearings tbo
Old 12-14-2011, 06:20 PM
  #243
generally, they don't work on off-brand stuff..
however TheBoostLab does work on many turbos. and will do a rebuild of just about anything.
take a look and send them an email
http://theboostlab.com/services/turborebuilds.html
Old 12-14-2011, 09:24 PM
  #244
jonnymerk's Avatar
I see a Batmowheel turbo build on the site. I'd have absolutely no problems with them swapping one into my turbo if possible.
Old 12-14-2011, 09:40 PM
  #245
link to the build?
Old 12-14-2011, 11:03 PM
  #246
jonnymerk's Avatar
link to the build?
Bulleye Power BatMoWheel
Old 12-14-2011, 11:25 PM
  #247
oh i thought you meant on here. yeah that supra isn't the only car. theres tons. especially the cummins and duramax trucks.
Old 12-15-2011, 06:08 PM
  #248
ford's Avatar
TTT... waiting for update!
Old 12-15-2011, 08:40 PM
  #249
RooTBeeR's Avatar
stupid supra...only ~1500rpm at full boost :shakes head:
Old 12-15-2011, 08:49 PM
  #250
autotrans or nls. full boost all the time.. hahah
Quick Reply: Bullseye Power Batmowheel for Ko4
