Bullseye Power Batmowheel for Ko4
Old 11-23-2011, 01:58 PM
  #151
Chevycobaltss3's Avatar
One thing is compare previous dyno with this. And boost and ect also need to be listed.good Tq though so far..
Old 11-23-2011, 02:00 PM
  #152
Also the horsepower curve stays linear and doesn't fall on its face so that's good.
Old 11-23-2011, 02:34 PM
  #153
JBThrasher22's Avatar
Good baseline now we just wait for the batmowheel to do a comparison.
Old 11-23-2011, 02:37 PM
  #154
sponge14's Avatar
Originally Posted by JacBlackSS/TC
they are in the description of the video its fully bolted and meth
thanks, I didn't go to youtube to watch it so I didn't see...
Old 11-23-2011, 02:53 PM
  #155
JacBlackSS/TC's Avatar
this is the baseline the wheel isn't on his car yet so everything that is listed in his video is what the car currently has done
Old 11-23-2011, 03:03 PM
  #156
elecblue06's Avatar
im guessing youre on stock clutch cuz those whp numebrs seem a bit low what what you have done/ that amount of torque but the HP line stays flat which leads me to believe you're going easy down llow
Old 11-23-2011, 03:55 PM
  #157
RYRO14's Avatar
No its got a cluthmasters stage 4 in it, yeah I thought the numbers would be a tad bit higher but it was pretty warm out (86 degrees) and the humidity was 42%. Another guy with similar mods minus the meth kit dynoed 320whp and 420wtq on the same dyno but his run had a lower humidity and the temperature 77 degrees and he was on 24 PSI vs mine which is only 22 PSI. I could have bumped the timing up as well. On this run it was 18 degrees peak and on the street we had it up 22 degrees with no knock.
Old 11-23-2011, 04:15 PM
  #158
EXsoccer1921's Avatar
this is on a stock Ko4.
Old 11-23-2011, 05:53 PM
  #159
Yeah I got that now lmfao I assumed he was dumping the batmowheel as a base file.sorry lmfao. Now I know why his HP doesn't fall like a lot of ko4s when they run out of breath.
Old 11-23-2011, 06:09 PM
  #160
RYRO just make sure you save that tune file and run that EXACT same one when the batmo is installed to see the difference. then retune it and take full advantage of the wheel.
Old 11-23-2011, 06:10 PM
  #161
Also list boost psi as well and Meth nozzle used.
Old 11-23-2011, 06:30 PM
  #162
RYRO14's Avatar
22 PSI and the medium sized nozzle that came with the AEM meth kit.
Old 11-23-2011, 06:44 PM
  #163
8gph?
Old 11-23-2011, 06:49 PM
  #164
Hey mark... It's a 20gph nozzle jk. I think its a 5 ..
Old 11-23-2011, 07:26 PM
  #165
ATLsilverSS's Avatar
this!!! i just dont want to see results post batmo where boost is 25psi and 22* timing with gains of 40-50whp.....that would be very misleading. he seems to have a conserative tune with a little lower boost than a lot of others run and very conservative timing for running meth. there will be potential for huge gains on his setup when the batmo gets installed if it is tuned more aggressively.
Old 11-23-2011, 10:20 PM
  #166
yeah. was kinda wanting people to tune their car to the fullest when testing pre-batmo
Old 11-23-2011, 11:00 PM
  #167
yeah thats what i would expect but i suppose as long as all variables stay the same then the comparison will still be apples to apples
Old 11-23-2011, 11:22 PM
  #168
RYRO14's Avatar
Sorry i was worried about knocking on the dyno, heard that sometimes happens and wanted to be on the save side by turning the timing down a tad. This is the same amount of timing I ran on pump gas. When I test the turbo i will use the same tune.
Old 11-23-2011, 11:26 PM
  #169
RYRO14's Avatar
Dont get me wrong its still a pretty aggressive tune.
Old 11-24-2011, 01:53 AM
  #170
yeah 385 is a nice amount of torque
Old 11-24-2011, 03:11 AM
  #171
Frogstofall's Avatar
I think those are great numbers, especially for a base tune. Can't wait to see the Batmowheel results.
Old 11-24-2011, 07:21 AM
  #172
bogalusahondakiller's Avatar
Makes me want a s259 with these wheels now since Louisiana hates e85
Old 11-24-2011, 07:56 AM
  #173
Boosted4's Avatar
Get back to work mother f*cker!! Happy Thanksgiving chief
Old 11-29-2011, 11:47 AM
  #174
i called bullseye today bill told me to call back in about two weeks they are waiting for parts to come in
Old 12-02-2011, 04:56 PM
  #175
AndrewSS/TC's Avatar
very interested in this, come tax time if gains are proven i will be purchasing.
Quick Reply: Bullseye Power Batmowheel for Ko4
