Car didn't do a cat warmup this morning.
Old 12-18-2014, 09:44 AM
Sl0wbaltSS's Avatar
Question Car didn't do a cat warmup this morning.
Has anyone else had this? I still have it turned on but it didn't do it's whole procedure. Car was at 48F when I started it. The car did do a long and slowly lowering 1100 to 900 and then sat there. I asked trifecta to turn it off but they said it's "illegal" for emissions even though I want it off since I have a catless downpipe coming.
Could it be possible they turned it off anyways?
Here's a video, it doesn't show from the very beginning though, but you can see that the car is at 62F and it's idling.
Old 12-18-2014, 03:21 PM
tomj77's Avatar
Is that what it does? If that's all it does at start up its off. It's not trifectas business if u want it off, it's not their job to keep it legal it's urs.
Old 12-18-2014, 05:04 PM
Omiotek's Avatar
Actually they can get in trouble for turning off anything emissions related...... Epa went after sct for tuning related issues as well as some other tuning companies awhile back.
Old 12-18-2014, 05:10 PM
Shanedude's Avatar
Your coolant is already warm enough to where it won't do a cat warm up at start. It has to be from a true cold start.
Old 12-18-2014, 05:44 PM
Sl0wbaltSS's Avatar
48F is warm enough!?!??!?
Old 12-18-2014, 06:02 PM
Shanedude's Avatar
I kept my cat warm up. Why don't you just wait over time and see if it's gone.
Old 12-18-2014, 08:49 PM
kzak104's Avatar
it should do a cat warmup at 48*F
i asked them to turn mine off to they said that the car wouldnt run right on cold start during cold cold days, doubtful considering locals have it disabled with hpt and theyre fine
Old 12-18-2014, 09:34 PM
footballplaya3k's Avatar
I asked them to turn it off a while ago for my car and they said no.
Old 12-18-2014, 09:41 PM
Terminator2's Avatar
That is because he has no Idea how to set the cold cam angles so it starts smoothly. Good MAF tuning helps too as you are in open loop so no fueling adjustment via fuel trims.
Old 12-19-2014, 04:06 AM
LNFwagonSS's Avatar
Am I the only one who thinks cold start mode sounds beast?
Old 12-19-2014, 05:03 AM
If you're catless and have a muffler delete its quite annoying and stupid loud.
Old 12-19-2014, 07:35 AM
I hated it. I loved when hp tuners have me the ability to disable it. Much smoother startup and much better cold drivability.
Old 12-19-2014, 12:24 PM
Wert842's Avatar
Hey Term, on the days were it was 30 or so the car would bog out upon start up. Actually enabled the cat warm up during the colder months and it's fine.
Old 12-19-2014, 12:55 PM
tomj77's Avatar
My car did cat warm up regardless what the temp was when I had it turned on
Old 12-19-2014, 12:56 PM
Weird mine never did on those same settings.
Old 12-19-2014, 12:58 PM
LNFwagonSS's Avatar
Even with catted DP? I'm catted with stock catback, muffler delete, that's why I think it sounds beast.
Old 12-19-2014, 02:12 PM
Yes it should not matter honestly. I was catted and then bashed the cat out.
Old 12-19-2014, 02:49 PM
Wert842's Avatar
ya it would run for like 5seconds and bog out.
Old 12-19-2014, 09:24 PM
Hmm strange. If you can try to log it for me.
Old 12-20-2014, 01:53 PM
CaptainXxAwesome's Avatar
About a year ago i had too drive my car in the cold till i bought my winter beater in January. I experienced the car not doing a cat warm up many times in the cold( this was with the stock tune). When i say cold i mean anywhere from -25 too -35 degrees celsius and sometimes around -50 degrees with the windchill. It would do regular cat warm ups when it was -15 degrees celsius or warmer. Im not quite sure the reasonings for this.
Old 12-21-2014, 10:01 AM
Wert842's Avatar
I'll try a log this spring. Ain't happening anytime soon man.
Turbo Johnny
02-21-2019 09:41 AM
vjoel2011
10-02-2015 12:11 PM
riceburner
09-27-2015 11:10 PM
Getaway_Driver
09-08-2015 09:41 AM
Getaway_Driver
25
09-05-2015 09:16 PM
Quick Reply: Car didn't do a cat warmup this morning.
