Car hard to start after filling up with gas
MFW I hear vapor lock on a fuel injected car
exninja (10-19-2016)
time to get a new tuner. Vapor Lock won't happen on a FI car unless you park the car on planet mercury
P.S.
Most modern engines are equipped with fuel injection, and have an electric submersible fuel pump in the fuel tank. Moving the fuel pump to the interior of the tank helps prevent vapor lock, since the entire fuel delivery system is under positive pressure and the fuel pump runs cooler than if it is located in the engine compartment. This is the primary reason that vapor lock is rare in modern fuel systems. For the same reason, some carbureted engines are retrofitted with an electric fuel pump near the fuel tank.
#40
Originally Posted by hawkssoccer11
you can check the evap purge solenoid now lol. its only two bolts and boom its off...... not that hard to do. its a 5 min job lol
#44
That conversion sucks lol.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Couldn't if got it for any cheaper even through Rockauto
#45
#46
So went to try my first cold start after the swap. Started it, made the weirdest sound and found idle quickly buy still stumbled. Left for work it and something felt off. Scanned it and got a code for incomplete circuit. Pulled over checked and I forgot to plug it in... DOH.
Hopefully it's better now.
#47
glad you found the fix man!! should be good to go now.
#48
Ezpz.
Now find a new tuner
