09 ss hesistating p0114,
thank you, I unplugged MAF sensor now the car runs fine. It is throwing P0119 when I have it unplugged. I did just have the engine rebuilt and my mechanic says a tune would fix this issue.... I talked with my tuner he told me my mechanic fucked up on something there... My cruise control isn't working neither, and fans are staying on way longer than they should.... any feedback? thanks for response
Umrdydlo
Umrdydlo
I put new thermostat, left the car wit tech today to check it, they also swapped coolant egt sensor? also on my RPD when I clear the codes the coolant reading is going from 165 135 120 70 60 54 then ----, fans are staying on a lil longer than usual, I have to unplug my MAF for car to be driveable if not its hesistation off. I put new fuel... Hes checking wiring now but engine is running smooth at idle and driving aswell I just cant go into boost right now.
Fans are staying on because the coolant temperature sensor isn't reading correctly. Beats them not running at all and the car coking all your oil and then spinning a rod bearing because it's overheating.
This has something to do with either your coolant temperature sensor not being plugged in, needing replaced, or there's an issue with your wiring.
Cruise control not working could be your 3rd brake light is out.
is it normal now that I rebuilt it for it to smoke a little from exhaust when I cracked cyl 3 it smoked like hell now I rebuilt it has some smoke coming from exhaust... tech says it will be about 2 months of that for it to settle the piston rings that true?
If you follow most piston/ring manufactures recommendations they should seat fairly quick. You still may have some smoking, it's tough to saw whats normal and what indicates a problem from the internet tho
no more smoking and also car has no codes p0013 camshaft position sensor? cleared the code it went away. has nt came back, idle fine, should I retune?? I put LDK pistons and pretty much stock build, cars 100 now
*TRIX*
07-20-2016 04:04 PM
timichaud
Tuning
07-06-2016 08:39 PM
