Flashing to stock from Trifecta
How would I go about going back to a stock tune from a Trifecta tune? I know I need to rent the cable; however,
A) where do I rent/buy a cable
B) wher do I get the stock file for my car
(Bought the car with the tune, want to go HP-Tuned)
EDIT: I now realize I probably should have posted this in the Tuning section. Sorry Mods. Move if required.
Well u can buy the cable from trifecta. Or borrow from someone. U need ur original tune file to flash it back to stock, if u know the previous owner, or contact trifecta see if they have it. The stock tune file is built into the tune file that is flashed into ur car
You might be able to request it from WOT - since your car is on their database, they should have no problem emailing you a tune file so that you can go back to stock.
There might be a fee - but it would invariably be less than what a dealer would charge you to put the stock tune for your car back on.
incase i'm interpreting you correct;
now that you have the file, you need a trifecta cable (you cannot use HPT to flash the stock/trifecta file to your car);
then you start up the program to flash your car;
select the trifecta file, then on the following window you select that you are going to flash the stock file.
be sure your laptop has a full battery, and that your car battery is good - needless to say, bad things happen when flashing and the connection is lost.
Same goes with HPT (afaik).
Oh no I know that but I'm not going to go to stock before I have HPT :P car proboaly wouldn't run too well I understand HPT well I just didn't know how to get rid of this horrible Trifecta tune ha-ha
