FTW-k04R vs ZFR In need of turbo swap!!
Old 07-02-2014, 03:50 PM
  #351
KMO43's Avatar
Originally Posted by sc4door
I've got the controller set higher than my max boost so it's not going full 20gph. I had 4 2gph nozzles and they weren't enough and I didn't want to have to keep buying nozzles at $20 a pop if I ever went bigger turbo and actually needed the extra fuel. The car does great on it. Part of it could be from the shitastic quality gas that we have where I live. I know it's supposed to be regulated but 93 where I live is not good fuel at all. Anywhere else I go is fine
Did you ever think of doing the 2gph in the manifold and a nother single in the cold sipe? That would be the best of both worlds!
Old 07-02-2014, 04:55 PM
  #352
sc4door's Avatar
I considered it but read that people had had problems with puddling around the throttle body when doing it that way. Originally I was going to just do a tb spacer or nozzles in the pipe but after reading some other people's past experiences is what made me do it the way I did. The only time there's a problem is if I set the meth too low, it bogs way down and goes too rich but it's doing good where it's at now
Old 07-02-2014, 05:15 PM
  #353
KMO43's Avatar
I think for puddling you would have to be running a lot of meth or have it not spraying right because it is going up into the airstream
Old 07-03-2014, 08:09 AM
  #354
sc4door's Avatar
I just read a lot of posts saying that the tb spacer byt made caused a lot of puddling issues so I didn't want to risk it. Plus I wanted to ensure that I had equal distribution to all cylinders. Another setup I saw after I did mind was somebody put 2 bungs (1 on each side of the purge solenoid) in the manifold. My one question has always been, with boost pushing back against the meth nozzles, how much do they actually flow compared to their rating?
Old 07-03-2014, 10:17 AM
  #355
KMO43's Avatar
I have a flow gauge and have turned up my pump pressure and i flow well over the 475cc nozzle size. I would turn up your pressure too and go to a smaller nozzle to make sure you get even flow to all 4 nozzles
Old 07-03-2014, 11:57 AM
  #356
sc4door's Avatar
I've got an AIS kit which I think is set at 250 psi. As far as even flow, I made sure all lines are the same length and it appeared to me to flow evenly when the manifold was off the car. I check my nozzles also to make sure I never have a clogged one and so far so good.
Old 07-03-2014, 12:09 PM
  #357
KMO43's Avatar
I'd ask the what the pump is set at from the factory because I think it's a "250psi" pump but set at "X" from factory. I was just wondering if the last nozzle on the manifold ould see less pressure so less flow. Also the closer to the cylinder the nozzle is the higher pressure you want to make sure you have proper atomization
Old 07-03-2014, 12:51 PM
  #358
sc4door's Avatar
Now that you said that I think it is set at 200 at the factory and my nozzles are set up in a t system instead of a rail with them all being on the same line. I have a "tee" the goes to 2 check valves, then those check valves each go to a "tee" which splits into 2 nozzles.
Old 07-03-2014, 01:04 PM
  #359
KMO43's Avatar
Ya OK so any drop you have should be even between all the nozzles. Maybe you'll get the same flow but better efficiency with a smaller nozzle size more pressure and max out the controller. I'm tuning all this weekend getting ready for my dyno so i'm gonna play with nozzle sizes and pressure
Old 07-03-2014, 02:08 PM
  #360
KMO43's Avatar
I'm thinking of switching to a manifold injection at 1-2gph nozzles then the rest from my coldpipe nozzle.
Old 07-03-2014, 02:59 PM
  #361
sc4door's Avatar
If nozzles weren't so expensive, I'd definitely experiment to see what the best way to go was. But at $20 a piece, I'll just keep them set how they are unless there's a problem. I don't foresee any but you never know. I am interested to see how well the meth helps at keeping the valves clean
Old 07-03-2014, 03:04 PM
  #362
KMO43's Avatar
Term said he worked on a LNF running meth and they looked new. I didn't run meth all winter so when I got my new pump I ran 50% water because it's the water that I heard steam cleans the engine
Old 07-03-2014, 03:28 PM
  #363
09outlander's Avatar
What was this thread about again?
Old 07-03-2014, 03:30 PM
  #364
Tacos
Old 07-03-2014, 03:32 PM
  #365
Tacos
And them good drugs
Old 07-03-2014, 03:34 PM
  #366
KMO43's Avatar
I'm pretty sure its about everybody waiting for me to fix my car and then get it dynoed so they can decide if they want to buy the turbo or not. Btw my intercooler is on it's way to my house now it's not in my hands yet but should be getting installed tonight.
Old 07-03-2014, 03:38 PM
  #367
thatzthastuff's Avatar
When's the dyno?? lol
  #368
sc4door's Avatar
I always run 50/50 water/meth
Tacos
I <3 tacos
Old 07-03-2014, 03:58 PM
  #369
Terminator2's Avatar
Originally Posted by ECaulk
And them good drugs
We talking about Mexico here?
Old 07-03-2014, 04:02 PM
  #370
KMO43's Avatar
First I love Tacos second I am tuning all weekend and throwing a LSJ back in so hopefully sometime next week or weekend i don't know how late the shop is open and I'm not taking time off to do it so I'll call after i'm ready should know Sat or Mon at the latest
Old 07-03-2014, 10:15 PM
  #371
tuned08ss's Avatar
Has the intercooler been shipped?
Old 07-03-2014, 10:19 PM
  #372
KMO43's Avatar
I left a check out for UPS but ZZP required a signature so they didn't leave it I don't know why ZZP did that!! It screws up all my plans for the whole weekend now
Old 07-03-2014, 10:26 PM
  #373
Somewhere around there
Old 07-03-2014, 10:29 PM
  #374
This whole thread sounds like a conspiracy, I'm officially calling this batmowheel 2.0 lol jk sorry to hear that hopefully they come back tomorrow
Old 07-03-2014, 10:35 PM
  #375
cfsnipers's Avatar
UPS left my ZZP intercooler in the middle of the effin hallway at my apartment! Had to tell a friend to grab it for me as I was out of the country lol. I hate UPS
Quick Reply: FTW-k04R vs ZFR In need of turbo swap!!
