Installed the Powell Air/Oil Separator today
Old 08-04-2015, 03:00 PM
exninja's Avatar
Originally Posted by Snail_SS
I have to check my TB then again to install a new TB
The cool kids go up from the bottom to take off the TB. IM isn't hard, but trying to twist it back in is kind of a pain.
Old 08-04-2015, 03:42 PM
i had a harder time trying to get the lower charge pipe out of the way when it was the stock one lol it really takes me no time to take the manifold off now tho so its easier and no jacking the car or anything involved
Old 08-04-2015, 03:56 PM
YelCal7's Avatar
Proof or bust ? That's the only way we will know if it's worth $400 ?...
Old 08-04-2015, 03:59 PM
umrdyldo's Avatar
I really wish someone had a before pic and a 1 year down the road pic with the seprator.
I have no doubt it works but would love proof.
Old 08-04-2015, 04:04 PM
I think everyone would
Old 08-04-2015, 04:17 PM
hawkssoccer11's Avatar
heres a link from powell. this thing does work. to be honest if you know the products that john sells and makes they are nothing but the best.
https://www.cobaltss.net/forums/2-0l...system-289225/
Old 08-04-2015, 04:24 PM
Powell makes great stuff and im sure it works but its always nice to see some pics of it working
Old 08-04-2015, 04:47 PM
exninja's Avatar
I think if he gets the latest design to showtime then there will be good results. Until then, I suspect that the gains will be marginal at best.
Old 08-04-2015, 04:59 PM
Yup im waiting on his new design
Old 08-04-2015, 05:50 PM
Given the amount of oil the filter collects and returns to the dipstick it does work. Iirc he has an update that will help make them work even better since it removes the pcv in the intake mani
Old 08-04-2015, 07:11 PM
  #36
63 Nova SS's Avatar
I will get pics this winter when I have her sitting all season.
Old 08-04-2015, 08:22 PM
  #37
footballplaya3k's Avatar
Well that's pretty much exactly what I have. A year old crate engine that has had this on it since new. I just need to get around to checking the valves out.
Old 08-04-2015, 11:11 PM
  #38
umrdyldo's Avatar
we would be forever greatful.
Old 08-06-2015, 07:24 PM
  #39
SS_2009_TC's Avatar
Pulling off my intake tomorrow to clean the valves
Old 08-07-2015, 05:07 AM
  #40
Borescope ordered, should be here within a week.
Old 08-07-2015, 10:09 AM
  #41
Nice cant wait to see the results. How many miles do you have?
Old 08-07-2015, 12:59 PM
  #42
I have about 1 year and 12k on the new motor.
Old 09-02-2015, 01:53 PM
  #43
soundjunky's Avatar
gains?
This only serves to improve upon the factory pcv system for cars running more than the stock 15psi & aftermarket tunes...
the instructions with the kit are comprehensive; it is essential that you either have clean valves or get them cleaned. This kit does not clean valves it prevents the continued deposition of oil on the intake valves. So far we have learned quite a bit about this coking issue. While DI valve coking is not unique to the LNF engine, its clear that bisecting the main vent line and inserting a drain back seperator does an effective job in the primary source of oil in the inlet tract.
The inlet manifold pcv valve can be defective, and I have found it so in quite a few de coke jobs on LNF I have done. If the IM pcv valve is reluctant to close until high boost levels hit it, or doesnt close at all, the build up becomes severe and the car really runs badly.
Sometimes I have encountered LNF with issues that the PCV upgrade evidentally could not deal with. Generally that has been cracked piston ring lands, damaged rings, or even broken charge pipes.
If the engine health is good, its reasonable to expect the upgrade will keep your engine running well.
(and more)
sinister did not know what the manifold looks like. There appears to be a lot of confusion about the PCV system and lots of opinions about it, many of them are wrong.
FOR THE RECORD.
There are two check valves in an LNF One is the FRESH AIR INLET (FAI) it lets metered air in from the inlet tube post MAF to the rocker cover port in the middle of the back of the rocker cover. There is a 4 mm orifice in this FAI tube. There is an UPDATED tube and valve as the nipple in the stock inlet tube can break from excessive pressure.
The other is the PCV VALVE ( dirty side) located in the inlet manifold as sox fan has show, that vents blow by gasses into the inlet manfold OFF BOOST.
The rocker cover port at the passenger side (front ) of the engine is routed stock to the turbo inlet port. It vents blow by gasses to the inlet side. As oil builds up combined with the blow by gasses running through the mezanine along the rocker cover to this port, it actually can drain out directly to the turbo inlet.
It is this issue that the Powell PCV upgrade oil seperator deals with, and drains excess oil seperated back to the engine.
As the engine tilts under accelleration or in cornering this issue with oil draining into the turbo inlet gets worse, which is why Wangspeed found he can collect as much as 500 cc of oil in 20 laps on track with the car, but collects less than that over a month of street driving.
The upgrade works.
The understanding of how it works, appears to be (how can I say this politely?) VARIABLE on here. There is a delicate balance of vacuum and the PCV orifices and paths of least resistance for blow by gasses to vent. The PCV upgrade really does a good job. The latest change as of July 1 to the system makes it easier for folks to plumb without issues; the next big change will be a full time vacuum pump but thats not needed for anything other than the extreme track guys imho....any parts of the PCV system not in good order like the FAI or the IM PCV valve will give issues, as will any leaks especially at the MAP sensors for example. Hope this helps
When I ordered my kit, I was told that essentially each kit is custom made in accordance to the parts that are on the car.
I saw no post (did I miss it?) where John seemed to imply the complete removal of the IM mounted pcv valve, and I was not told of any optional setup which eliminated the IM pcv valve;
IMHO, retaining it, as another safety precaution might be the prudent move...
Old 09-02-2015, 02:05 PM
  #44
gains?
(and more)
His newest prototype (at least of last mention it still was in the development stage) does remove the IM pcv iirc
Old 09-02-2015, 02:25 PM
  #45
exninja's Avatar
gains?
(and more)
Only thing I saw is that the new design would address the oil entry at the IM PCV. It may relocate the PCV itself, but there would still need to be a "check" valve at that location. You can't run open or orifice there or else you would put positive pressure into the crankcase each time you enter boost.
Depending on how the car is running, the IM PCV is definitely a source of oil in the IM. When I was troubleshooting an apparent vacuum and bogging issue when I replaced my engine I found fresh oil on the IM side of the throttle plate after few miles of running. The only way I could see that getting there was through the IM PCV. That lead me down a rabbit hole of trying to diagnose the PCV system. The problem ended up being entirely different, BTW.
Old 02-05-2016, 11:40 PM
  #46
96S1's Avatar
Did anybody install the new version yet? I'm going to get this when I get the ZZP head/cams package and install together.
Old 11-27-2016, 12:30 AM
  #47
CaRRiED's Avatar
Updates on how well this is working?
Old 11-27-2016, 07:00 AM
  #48
63 Nova SS's Avatar
Colodude ran his this year but sadly didn't get to run the motor very long.
Old 11-27-2016, 07:03 AM
  #49
63 Nova SS's Avatar
I've ran the version 2, like the op had pictures of, for 2 years and it does help.
Old 11-27-2016, 08:51 AM
  #50
Solaris99's Avatar
It took me forever to finally get to cleaning the intake valves. So it's going to be a little while before I remove the intake manifold again. I should know this next September how much it is helping.
Quick Reply: Installed the Powell Air/Oil Separator today
