Interceptor annunctuator setup
Can some please explain to me how to set up the annunctuator on the interceptor? Iv tried and tried but only thing that works is if I set up p1 only. What is p1 and p2 , p1 or p2 settings for, does it output to a wire trigger or something? U can see 2 readings at the same time on the gauge can u not set a warning for both or just for one? Iv tried for both and it just don't work. I don't think I know what I'm doing lol
What are you wanting to use them for? As a warning? I once had a dial stage controller hooked up so that when the car was at 100% throttle amd ata set rpm it would trigger through a relay and kick in the second stage to spike boost again on the stock turbo to give a better torque and hp curve
ThoR294
10-04-2015 08:44 PM
