LNF Redemption Build
If you want to save a little bit of money on the initial build you can stick with ZZP f40 dual mass clutch setup. Infra said his never slipped and even held on a 550lbft dyno pull. But he has 259et so I'm sure his boost comes in around 4k. Just something to consider.
Yea I probably will do the dual mass flywheel at first. I'm having to use my car for a long commute for school, so this build may be a slow on going process. I might swap a hx35 with the turbo kit on my stock block and keep it really conservative 93 25psi tune. We'll see. Earliest I can get the swap kit, if even available, will be late January though.
