Looks like I need a new engine
Old 11-27-2016, 06:48 AM
  #126
63 Nova SS's Avatar
The good news with going to the drag strip is that you only go WOT for what, 13 seconds at a time. I was talking with John Powell earlier today and he made a good point; track cars see roughly 1:30 WOT on a 2 minute lap, and a session is 15-20 laps.... that is a lot more heat than you will see under any other conditions. In fact, I don't know any other Cobalts running a ZFR that are tracked. I think that is why nobody with the 6758 is having anywhere near the overheating issues I'm seeing.
Adrian- is there anyway you can run some type of fogging system for the intercooler. No doubt your generating more heat for an extended period than anyone else sees. I can't imagine how much punishment your track days put on a motor. What kind of intake temps do you see?
Old 11-27-2016, 10:05 AM
  #127
For the road track he'll be running lower boost, and getting the oil line away from the turbo heat (pretty certain some of the heat issues were related to the oil line being so close). We were going to see how his temps (intake and coolant) the day the line broke.
Old 11-27-2016, 11:15 AM
  #128
63 Nova SS's Avatar
Sorry you all didn't get the chance to monitor it. Wonder how long this tank lasts and how good it does. Thinking maybe Ryan Colon has something like this.
Old 11-27-2016, 12:26 PM
  #129
KMO43's Avatar
The gen3 used a difference oil feed for the turbo which will be way easier to route away from the exhaust
Old 11-27-2016, 12:29 PM
  #130
colodude18's Avatar
Attachment 9845
Yes, he does. I don't think it would last long enough, plus it would be expensive to refill it - even a fire dept typically charges $25 to fill a breathing air cylinder with compressed air. I don't think you need NO2 for cooling radiator and/or IC.
In terms of cooling, if we still need more with the new engine and reduced boost, I'm thinking a bigger custom radiator will be the first step. Maybe vented hood (although my budget for that just went in the LDK) and we haven't really tested the effect of the oil cooler yet. I have a bigger oil cooler core if we need it as well. And finally, more for longevity of the trans, a trans cooler that Powell is designing. But one step at a time
Old 11-27-2016, 12:35 PM
  #131
Devin86's Avatar
I wouldn't do the back to back passes like you say especially if your doing a burnout because it's really hard on your clutch. 2 years ago I did 3 back to back passes on my lnf clutch and it's the only time I've really ever smelled my clutch. I could tell a huge difference in it for awhile driving it, figuring I glazed it.
Yeah no burnouts I just use good summer tires so there is really no point in getting them that hot the pavment in the summer here you can cook a egg anyways lmao I might get more serious this year and get some race rubber just to get that new turbo power down and smoke a few locals that think they have fast cars lmao
Old 11-27-2016, 07:57 PM
  #132
LTBALTBMX's Avatar
So did the oil light ever come on? I thought there was a pressure switch to kill the engine when **** like this happens?
Old 11-28-2016, 11:23 AM
  #133
colodude18's Avatar
Not while I was driving it. It may have come on while the car was idling when we were staring into the engine compartment...
Old 11-29-2016, 09:43 PM
  #134
KMO43's Avatar
So the new stock line is 14in and I bought a 16in
Old 11-30-2016, 10:58 AM
  #135
colodude18's Avatar
Does that allow you to route it along the other side of the turbo?
Like so: (not my picture)
Old 11-30-2016, 11:07 AM
  #136
user 72239's Avatar
Adrian, My ZFR oil line went the opposite way. we used a 120 degree angled AN fitting to -4 AN hose that went around the top of the compressor housing and down into the oil fitting on the block.
Old 11-30-2016, 11:20 AM
  #137
colodude18's Avatar
That would also be a big improvement. Mine went right between the hot side of the turbo and the heat shield
Old 11-30-2016, 11:29 AM
  #138
What's the best place to get the hose and all that stuff?
Old 11-30-2016, 11:40 AM
  #139
user 72239's Avatar
Got all mine from Summit racing.
This is everything for coolant and oil. I can't remember what fitting goes on the block itself. I think its another earl fitting
Snail_SS (11-30-2016)
Old 11-30-2016, 12:16 PM
  #140
Thanks Leemanfor I'll wait to see if someone will pitch in with what's missing.
Old 11-30-2016, 12:39 PM
  #141
For oil use the aeroquip brand. When we did leemanfor's I didn't know there was a significant difference (as Omitek and Zoomer both pointed out use Aeroquip brand)
Old 11-30-2016, 12:41 PM
  #142
63 Nova SS's Avatar
If I get in gear I was going to send y turbo to omiotec and he was going to use it to mock up lines. Thinking he was going to sell them direct, with heat wrap all ready to go.
Old 11-30-2016, 12:42 PM
  #143
Also add a 120* -4AN fitting to leemanfor's list (must of ordered that separate)
Old 11-30-2016, 01:23 PM
  #144
So you mean to get the aeroquip hose instead of the summit brand?
Old 11-30-2016, 01:28 PM
  #145
Yes. For the fittings, not sure how the tubing is for the summit brand. Leemanfor didn't have issues, but I'd wait for input from a more experienced person on the actual lines.
Old 11-30-2016, 01:30 PM
  #146
user 72239's Avatar
Yeah, you dont have to use those red ones. I just liked the way they looked "because ricer".
Old 11-30-2016, 01:39 PM
  #147
sounds good
Old 11-30-2016, 04:49 PM
  #148
colodude18's Avatar
Well, there she is!
BTW that K04 is gonna be for sale soon!
mzspd (11-30-2016)
Old 11-30-2016, 04:53 PM
  #149
Haha great man put that thing on!
Old 11-30-2016, 05:11 PM
  #150
KMO43's Avatar
I would recommend you check out ur turbo 1st. It would have been the 1st thing starved of oil
