Meth or Aux Fuel Rail
I am working on finishing my spare intake manifold and have come to a fork. Since it is a spare and time is not a big deal, I want to add in bungs for either meth or a secondary fuel rail.
Car is a 2009 LNF that is getting a 20g turbo.
Help me decide.
Help me decide.
One of my best friends is a fabricator for a speed shop. Builds tube cars, cages, RB swaps, turbo kits, etc. He is the one that will be doing it.
I was thinking of just using a 2.2 rail cleaned up to have only the test port, mounts, and a -4AN fitting installed.
I have no idea if I will go to a bigger turbo, but I want to have more fuel than not enough.
If that's all u have then another fuel rail won't do much good, unless ur running not so much boost and timing of u go more power. Ur still gonna be injecting 93 octane if u want better quality fuel to make more power then u wanna run meth if u have nothing better for fuel. It will let u run more timing or boost or both. But I wouldn't put one on each runner unless u have a failsafe gauge for all of them. I'd just drill it in back above the tb.
With a 20g, you'll never need that much fuel to justify running a secondary fuel rail. Even with e85 that's a bit of a of a stretch. Especially when Opels and fuel cam can more than handle that. Let's put it this way....
Even with the added fuel demands of e47, with my car making 470whp, I only need a single 30lb additional injector to keep my fueling in check. With that little injector, my pulse widths never see higher than 6ms and idc never sees higher than 30%.
So long and short of it. Even with a td06, you're likely to never need that much fueling, especially on 93.
Now in the long term, it certainly wouldn't hurt to have a port injected manifold sitting in the parts closet for when you decide to go with an even larger turbo on e85. Then that would be a very viable part to have kicking around.
DI is superior for actual fueling. It's only real drawback is noise and the fact that it can't support as much fuel due to a smaller injection window. For all practical purposes it's better. But port injection cleans the intake valves, is quiet and expandable. Lexus has been using both on some of its engines for a while now.
It's not a terrible idea, but timing the injectors would require some sort of a standalone system along with an external cps and kps to be optimized and keep the engine happy.
califcarm
03-04-2016 09:44 PM
