Mild transmission clunk when shifting?
its normal for this tranny something to do with the fact that its a high performance tranny.. apprently other high performance trannys do this as well.. or so I have been told.. shift at 3k you won't notice it anymore, or as much.
i get it real bad lol, stage 4 clutch grabs up pretty hard!!!!! big clunks lol.... aint nothin to hurt it though, i mean, what can i do, a stage 4 clutch is just gonna hit hard... its also very noisy at idle... makes a lot of clickity clackity noise... really fast... when i push the clutch in, it stops lol.. people always ask me what that noise is, and i tell them, and they're like, oh, yeah, that will do it...
Sure is loud and un-nerving but I figure it kinda sounds like the constantly adjustable pressure plate on the clutch. Our cars have the plate that adjust to how thick the clutch is, so as the clutch wears over time the distance is always the same hence the adjustment, meaning always the same grip.
Mines been doing it since day one.....moving sound are normal.....
My 2 cents? TURN THE RADIO UP!!!
No really. The guys talking about the trans making noises because it's a performance trans are probably close. But I believe the noise is actually caused by the differential and especially if you have LS. The Limited Slip unit is an all gear unit which is a very high performance piece. I't's an all gear (no clutch packs) and, I suspect, it uses some straight cut gears which because of the required clearances make more slapping noises than the normal helical cut gears which are normally used in the grocery getter differentials simply because they are quieter. The TC uses a Quaife all gear unit. The design is used in some of the worlds highest performing cars up to and including F1.
Of course this is only my opinion based on online references like the following;
http://www.autotech.com/quaife/differentials/diffs.htm
http://www.autotech.com/quaife/diffe.../diff_apps.htm
Newfoundlight (08-19-2023)
If you lift the car, on the tranny there will be a drain plug low, and identical to it theres a fill plug up higher. Crack the fill plug and add the additive. just realized as im typing this its from like 2009 haha but if you still want to add some thing its right there
#36
Normal on these cars, I was wondering as well when I bought the car. However a great mod to improve shifting drastically is the Powell Front Transmission Mount. No more wheel hop, shifter is more precise and everything feels more firm. You won't regret it and it's not expensive (110$)
#40
Transmission Clunk Not "Normal"
See if we can get this old thread going again.
Even though many said the tranny clunk is normal, I don't think it is. I have a 2009 SS with 244,000 Kms that doesn't make any clunk sound at all. Just bought a 2010 SS with 108,000 Kms yesterday and it has a clunk when making a normal 1st to 2nd shift. Almost seems like something loose in the front end or a mount issue.
Any other experiences or advice on this topic ??
Thanks
Thanks
#41
Thanks
Thanks
Almost impossible to diagnose online. Especially if you're disagreeing with the general consensus.
#42
I've had 3 different SS/TC sedans and a coupe. The coupe and the current ride both have LSD and are both noisy/clunky. The other two sedans I had without LSD didn't make nearly as much noise.
Edit - Just to be clear, the F35 is loud and clunky. Period. I do believe though that the LSD does make additional noises.
cluelessk (01-31-2017)
#43
#45
Had the car checked at newly taken over local transmission shop. They told me was something internal in tranny and would be $600 for R&R, $600 for bench time plus parts.
Went on to other trusted tranny shop that has been around for years, told me after test drive he didn't think it was transmission.
Then went to garage I usually deal with. As we suspected transmission was fine, he knew right away from the test drive. To make a short story long car needs new lower control arm, the whole bushing is sliding up & down in the control arm. So it bangs or "clunks" when an aggressive shift is made.
Thanks for any help.
