My build
Old 11-19-2014, 10:15 AM
  #51
InfraRedline's Avatar
I've pushed ~600whp on my girdled Gen 3 2.1 build. I wouldn't see even a non girdled Gen 3 giving up at anywhere around that power level, but who knows.
Old 11-19-2014, 10:49 AM
  #52
cmiller8006's Avatar
I really doubt that the girdle helps the gen 3 much if any at all. The gen three has the benefits of the girdle and better cooling capabilities. But with that said, I don't see either breaking at 650, I was prolly in the 560-580 range at Chicago.
Old 11-19-2014, 10:55 AM
  #53
Yeah that's why I said I don't see even a pistons/rods only Gen 3 having any issue. GM seems to have nailed it with the block design.
Old 11-19-2014, 02:16 PM
  #54
KonnerTomlinson's Avatar
glad to hear that , once I get this fuel system mapped out im hoping to start making some POWWWAA
Old 11-20-2014, 05:01 PM
  #55
574
574's Avatar
Thennnn you'll see you want these slicks I've got
Old 11-20-2014, 05:24 PM
  #56
I want radials instead of slicks but I'm still debating it haha
Old 11-20-2014, 06:21 PM
  #57
raver0789's Avatar
Which cylinder is farthest away from the timing chain? I'm guessing it's number 4. The way the gen 3s are laid out that appears to be the weakest cylinder I would say just by looks.
http://i1189.photobucket.com/albums/z440/raver0789/received_10152584413864262_zpsgevxjai2.jpeg
Old 11-20-2014, 07:33 PM
  #58
SSlobalt's Avatar
Well snit. I thought cylinder number 1 was by the tranny.
Old 11-20-2014, 07:41 PM
  #59
574
574's Avatar
#4 is next to trans
Old 11-20-2014, 08:04 PM
  #60
Originally Posted by raver0789
Which cylinder is farthest away from the timing chain? I'm guessing it's number 4. The way the gen 3s are laid out that appears to be the weakest cylinder I would say just by looks. http://i1189.photobucket.com/albums/...sgevxjai2.jpeg
is that your engine ?
Old 11-20-2014, 08:14 PM
  #61
The compressor map will be different with the .63 housing. It'll choke up for sure and never reach peak flow. I'm going to aim to get it working on pump gas first, make 500, and then up the boost. 600 or disappointment lol. I figure the block can take 700whp and 45psi with ease.
sorry for creeping through your posts haha is 45psi deemed safe on the Gen3 block? I was curious as to the max boost I can run on mine as well , I figured 35psi consistently and a 40psi run a few times
Old 11-20-2014, 08:16 PM
  #62
raver0789's Avatar
This was my gen 3 stuff that was going together but I sold it to buy cmiller8006's block. The guy who bought it is putting it together and this is his now. Boost isn't the issue it's detonation that kills these motors.
Old 11-20-2014, 08:35 PM
  #63
gotcha , I was just afraid of cracking/blowing open the sleeves in my gen3 block from running too high of boost. Thanks for the quick reply !
Old 11-28-2014, 05:09 PM
  #64
raver0789's Avatar
Towed the truck up north to get the kit fabbed up. It's gonna be a tight fit in the engine bay for this turbo lol.
http://i1189.photobucket.com/albums/z440/raver0789/IMG_13104695295731_zps203gijqi.jpeg
http://i1189.photobucket.com/albums/z440/raver0789/20141127_153825_zps3ekgxeiu.jpg
Old 11-28-2014, 10:14 PM
  #65
Nice
Old 02-09-2015, 03:53 PM
  #66
raver0789's Avatar
Well ran into the first problems. There always are when doing a build
The motor i bought from cmiller8006 uses the ati damper. The sky redline's power steering runs off the stock damper on the car. I was talking to omiotek about this. Either i can run the stock pulley (I rev to 8k and have stage 3 lnf cams. I want the motor to last, stock damper is probably not a good idea) or i find some way to run the cobalt system. Or I run another aftermarket damper. Anyone have any thoughts and insight?
You would think I would have seen this coming
Cheers.
Old 02-09-2015, 04:25 PM
  #67
KMO43's Avatar
Cheers.
Old mr2 had an electric power steering pump that would be an option you could make a couple custom hoses and be ok. Also you'll save a couple hp!
Old 02-09-2015, 06:16 PM
  #68
raver0789's Avatar
Argh. These things never go smoothly. I was told the cobalt one won't work because it uses the bcm. Is this the case?
Old 02-09-2015, 08:24 PM
  #69
KMO43's Avatar
Old 02-09-2015, 08:28 PM
  #70
Terminator2's Avatar
I believe you are correct.
Old 02-09-2015, 10:32 PM
  #71
Omiotek's Avatar
dude I told you it wont work due to the bcm and if you get any of the electrical wrong you will pop fuses left and right or the car will not start what so ever. Its a lot more complicated then you think and you will probably want to kill yourself trying to figure it out.
Call ati and they should be able to help you with a drive setup. most of that stuff is custom made. you should be able to get something that bolts up to the dampner itself. that's how the fluid dampner setup is.
they will make your anything you want
http://www.atiracing.com/products/da...hubs/index.htm
Old 02-10-2015, 12:08 PM
  #72
raver0789's Avatar
You did tell me, but I figured I would ask around as well.
I will be calling them, thanks.
Old 02-10-2015, 12:25 PM
  #73
raver0789's Avatar
They are going to try to make a custom pulley for me, I just have to get it all measured up and send it over to ATI. Thanks Omiotek.
Old 02-10-2015, 12:32 PM
  #74
Omiotek's Avatar
Welcome. I'm sure they can do it. I've seen a lot crazier custom stuff done by them
Old 02-10-2015, 12:51 PM
  #75
raver0789's Avatar
Yup. It's just time frame. Gotta get the ball rolling asap as it's gonna take at least 60 days to get the custom part made.
Quick Reply: My build
