No_ss build thread
#226
It doesn't look completed
#228
So i almost had it all set up the other day and i messed up on the harmonic balancer install and as i was torquing it down i didnt have the balancer on the keyway and it destroyed itnas you can see, also cracked driven gear for balance shaft timing so i ordered a new one of those along with a new harmonic balancer
#230
Haha that would be an expensive way to show me
#232
I guess so
#235
Yup
#237
So, got some tools in the mail today all great deals cause student discount. Got my cam and balanceshaft timing done today. Just need to bolt valve cover down, install charge pipe, air box, engine mount, new harmonic balancer, new drive belt, reinstall drive belt tensioner, front engine cover. Will be done monday.
Yes I fucked that keyway up bad.
Waiting on my silver eagle 3/8 drive set to come in the mail
What i got:
-ADV 30pc metric impact set 10mm-24mm
-18pc silver eagle wrench set
-52pc 1/2 drive silver eagle set
-57pc 1/4 drive silver eagle set
-matco pick up tool w/led light
-matco 6" 1/4 drive breaker bar
-matco 10" 3/8 drive breaker bar
What i got:
#242
Fuel pressure looks great
#244
Well, trying E85 and kevin is getting data from that along with knowing if my cars fuel pressure can handle it, maybe he can shine some light on what he knows as of now, but, still drives smooth and I love the smell of it coming from my exhaust! First E85 tune did 4.5sec 60-100mph
#246
I am going to do my fueling thread but I'm not home and am quite busy
#248
#249
You wanna be fully spooled when you hit 60. That was it takes out the variable of when the pull was started. Most times for supercars are taken from a standing run not starting at 60 and doing the pull I believe
