No_ss build thread
#327
3pcs
#339
is it the raising up that helps traction or just keeping the engine and trans planted and not twisting from the torque and wigglin' about?
#341
It's a rotation of the entire assembly (engine and trans) to align the axles better to prevent wheel hop due to axle angle. Powell is the one who worked with GM Perfomance in developing a different mount due to the Cobalt platform being initially engineered to function better with automatics.
#342
For awhile (maybe zzp changed their design to match Powells) zzp's mounts where just a direct replacement of the stockers with firm bushings and didn't actually rotate the engine to the position it needs to be.
#343
#345
The arbitrary spacing isn't going to line up the axles right. That's where Powell's comes in, his adjusts the engine, in the front and rear mount, to the correct angle to line the axles up.
#347
I'm not going to explain geometry to you, let along suspension geometry. I'm not saying it doesn't improve the angle, but there is a sweet spot and Powell has it. If zzp offers different spacers they aren't basing it on lining axles up.
#350
I have had both, and will say I had more vibration with the ZZP mount by far. The ZZP mount was better than factory probably because it didn't allow much movement. The Powell mounts I have now though are better. With the same tire arraignment I could get wheel hop using the ZZP setup, have little to none with powells. ZZP mounts are pretty though.
