No_ss build thread
Old 01-17-2017, 02:05 PM
  #376
no_ss's Avatar
The angle of the axle has nothing to do with suspension geometry. It changes the way yhe power is delivered to the hub and direction of the power.
I still see no credibility of yours so at this point its really not worth arguing with you when I know 100% you are wrong.
Old 01-17-2017, 02:08 PM
  #377
Sorry I group axles into suspension and you can't look past my comment about geometry. There is still a point of lining the axles up and rotating the engine and trans assembly to line things up.
Old 01-17-2017, 02:15 PM
  #378
no_ss's Avatar
okay so you openly admit axles have nothing to do with suspension, great. But please explain where a mount that is same height as a stock mount, same size spacer is ARBITRARY compared to powell mount when it is one in the same?
Old 01-17-2017, 02:20 PM
  #379
Also I'm not going to waste time comparing a set of zzps to Powells, Powell generated them first while working with GM. Anything after that is at best a damn copy, yea they might look different but the important points are copied.
qfe
I also don't recall you comparing the zzp to powell spacers from a dimensions standpoint.
Old 01-17-2017, 02:25 PM
  #380
no_ss's Avatar
qfe
but I do recall you saying zzp is just arbitrary spacing, when its the same as powell.
Old 01-17-2017, 02:37 PM
  #381
FLASH1970's Avatar
I don't understand this 'lining things up... the axles have 2 knuckles so any alignment being off I would think would be resolved. unless maybe this mount(s) puts the half shafts coming out of the trans & running along the block more directly over the wheel somehow improves the amount of grip you have. but then wouldn't it torque the passenger side engine mount and DS trans mount causing fatigue?
Old 01-17-2017, 02:50 PM
  #382
no_ss's Avatar
When it raises the rear of the engine and tilts it forward it brings the axles in line to where the power is distributed more lateral to the wheel. The knuckles really only change when the suspension moves. In this case youre changing the tilt of the axle by moving where the axles meet the transmission at the differential. On stock mount and no spacing the axles point upwards changing the direction of the force being delivered to the wheel in the z-axis
Old 01-17-2017, 03:06 PM
  #383
no_ss's Avatar
And the powertrain sits in one position more less with some flex naturally due to the mounts having some give but suspension is constantly changing so one way to bring the axles into line with the wheels is raising the point where the axles meet the transmission and a consistent way of doing so is rotating the engine forward and raising the rear of the engine (and transmission)
Old 08-19-2017, 12:35 AM
  #384
no_ss's Avatar
well. Updating you guys I guess. Left for a bit cause I was getting annoyed. Getting a 4.05 trans soon, 2nd grinds now. Gutted the rear out a decent bit, did end up taking out that insulation out where the seat was that you can see in the pics. Got new wheels too. Gonna gut it more and also want to get a z54 at some point. So far the k04r has been great on e85.
Old 10-20-2017, 04:31 PM
  #385
no_ss's Avatar
K04r blew about a month ago, ordered a 7163 today.
Old 10-20-2017, 04:36 PM
  #386
How long did it last?
Old 10-20-2017, 04:41 PM
  #387
double clutch's Avatar
Not long enough
  #388
Damn the ko4r's aren't lasting long
Old 10-20-2017, 07:59 PM
  #389
Where you out of warranty already? Haha I guess you couldn't resist getting the bigger turbo
Old 10-30-2017, 09:12 PM
  #390
no_ss's Avatar
Originally Posted by double clutch
Not long enough
This ^ 14 months and probably 10k or less miles.
Seems to be a thing with them.
I bought it private party, no warranty. Makes for a cool shelf piece though.
Old 10-30-2017, 09:35 PM
  #391
I guess good thing I got rid of mine
Old 02-11-2018, 02:12 AM
  #392
CaRRiED's Avatar
updates.
Bandit2941
01-12-2017 08:06 AM
soccerkid13
03-03-2016 11:10 PM
02-29-2016 05:47 PM
Chaos_Six
02-09-2016 11:32 AM
blueLNFftw
01-28-2016 09:04 AM
Quick Reply: No_ss build thread
