Questions about ZZP catless downpipe.
I'm contemplating picking up a catless downpipe for my next mod, but I have a few questions first: 1. Is it worth it for $140? 2. ZZP says that the slanted o2 opening won't set off a CEL for the cat, but I find that a little hard to believe. Does anybody make an o2 simulator that can be used to eliminate that o2 sensor? I used one of those on my 98 Tahoe a few years ago and it worked just fine, but that o2 sensor was further down the exhaust system.
Thanks!
Thanks!
Thanks!
Thanks!
its not too bad to do. the hardest part is trying to figure how many extensions or beers your gonna go through the get the top bolt off because its so close to the frame and its just a pain to get off sometimes haha
If you want a cat'd DP and you'll be near Denver anytime soon I just switched to a cat-less and have a cat'd to sell. I have to put the stocker on for emissions since they rejected the hi-flow cats even though it passed the sniffer. Not sure of the power difference but it does spool a little faster with the cat-less
This might be a stupid question...but, if I wanted to run the downpipe that doesn't have the place for the o2 sensor, what would I need to do? Does anyone make an o2 sensor simulator or would that code need to just be disabled?
Just trying to look at my options.
Depends how careful you are removing things, the one that might need replaced is between the exhaust and the dp.
Not sure how you would run that, I just switched the code to set but not illuminate
Does that o2 sensor affect how the engine runs at all? Also, how did you disable the code from illuminating? I'm assuming it's a special scan tool? Or will the trifecta software I got with my tune give me the option? I only ask because saving $40 on the downpipe would be nice lol.
Hptuners is how I did it. Not sure on how it effects the engine running I never noticed an issue when it was in the angled o2 bung. Right now I have the cat efficiency code off but the o2 sensor installed in the gas stream.
Alright. So is the general consensus that the angled o2 bung is the best way to go? It's $40 more -_-
how much does hptuners charge for something like that?
HP Tuners is the tuning software that would be used, so if you had the software it would cost you nothing. If you need to buy credits to unlock your particular model year it's $100 i think.
Really chris88z24, really, are u really sure a catless will lose power over a high flow cat? Are u certain of it? U got a couple of dyno sheets that can support that statement? A back to back comparison with just that 1 change?
If u don't, I think it might be best if u don't make statements that dont make logical sense and don't have data to back it up.
Catless is good if you want your car to both sound and smell like ****. You will NOT make more power over a high-flow setup. There are 700hp factory cars that have cats, your ******* Chevy Cobalt is not going to benefit from not having one. I've had so many different exhaust setups over the years that I'm not even going to bother arguing any further with you noobs.
HOWEVER, if you do insist on not listening and going Catless on an LSJ car, I HIGHLY RECOMMEND you use some sort of silencer in the exhaust to combat rasp.
Really, ForceFedDummy. You've been on this forum for less than two years. I don't need to post a ******* dyno sheet to prove a point. I have experience pal, 8 years of messing with these cars in particular. If Catless was better i would have my car setup that way, lol. And so would Staged07SS, even though he doesn't drive his car very much...
