Random misfire - Cobalt SS Network
Technical Discussions ONLY!
Thread Tools Search this Thread
Old 08-17-2012, 01:55 PM   #1
Random misfire
Since I got my cobalt I've had a flashing CEL here and there that went away after the car started to move. I changed the plugs and the issue went away for a while. Now its back again and happens every time i come to a stop for more than a few seconds. Is this a common issue and what else other than the plugs should I look into?
spina74 is offline   Reply With Quote
Old 08-19-2012, 01:25 AM   #2
jmiller15's Avatar
Images: 64
Have you been attempting WOT runs or NLS when under engine operating temperature?
It's really hard to say, are you running different plugs? I've heard people running anything other than NGK or OEM having issues...
Give us some background, used/new purchase? Mods?
jmiller15 is offline   Reply With Quote
Old 08-19-2012, 02:02 AM   #3
Aleksey's Avatar
Make sure you don't have Denso plugs, they are NO GOOD. NGK/ACDelco Iridium is what you need/want/must have in there :-p
Aleksey is offline   Reply With Quote
Old 08-19-2012, 06:34 AM   #4
No i never go WOT before its warm. The plugs are NGK iridiums. I bought the car used with a aftermarket ic and since then i installed a catless dp, forge bpv, and k&n sri. The flashing cel didnt fully go away after the plugs because it still popped up here and.there it just wasnt as common as it was before the new plugs.
Old 08-19-2012, 03:16 PM   #5
jmiller15's Avatar
Images: 64
Quote:
Hrmm, any loss of power? Can you run a OBDII scanner and get us some codes if there are any?
Old 08-24-2012, 01:41 PM   #6
Nope no loss of power, and nothing shows up when scanning even with HP tuners plugged in.
Old 08-24-2012, 01:52 PM   #7
Images: 16
regap the plugs when u bought em? make sure they are all 0.32-.033 for the lnf.stopped my misfire.
victoryredturbalt is offline   Reply With Quote
Old 08-24-2012, 02:20 PM   #8
Quote:
I regapped them to .32 when I installed them. I've only ran WAWA 92 in the car. East coast guys know what I'm talking about. Would shitty gas cause a miss?
Old 08-24-2012, 02:54 PM   #9
Just out of curiosity how long does the light flash? Meaning the time between when it comes on and then turns off and then back on again?
DPveritasGold is offline   Reply With Quote
Old 08-24-2012, 07:59 PM   #10
Images: 1
Are you tuned for all your mods?
SSlobalt is offline   Reply With Quote
Old 08-24-2012, 09:49 PM   #11
Images: 16
check your coil packs?
Old 08-25-2012, 12:40 AM   #12
The cel only flashes while I'm at idle mainly after I've been driving and come to a stop light then goes away after i start driving again. I'm not tuned for my mods, but when I got the car it only had an IC on it and it has a miss too. I've yet to check the coil packs. How would I test them if no codes are thrown.
Old 08-25-2012, 04:00 AM   #13
Images: 6
Could be the intake skewing your trims dramatically. Make sure your filter is pointed in the correct direction. Could also be a massive boost leak. Yes you can still build full boost with a large boost leak, ask me how I know...
FasterIsBetter is offline   Reply With Quote
Old 08-25-2012, 01:28 PM   #14
Quote:
I have 2 hoses that aren't connected that run under the intake.....i have no idea where they go
edit: scratch that, the previous owner did the bpv tank mod
Old 08-25-2012, 01:55 PM   #15
Images: 6
No hoses should be disconnected. Send a pic of them and their location exactly and we can tell you what they're for.
Old 08-25-2012, 02:36 PM   #16
Images: 1
He did the vac tank bypass and left the tubing loomed, I bet.
OP: Like Faster says, I'm betting it's your fuel trims. Check for boost leaks, then get tuned for the mods and see what that does, or go back to the stock airbox and see if that helps.
Old 09-25-2012, 08:57 PM   #17
Went back to the stock airbox, still has the flashing cel when i come to a stop, and I tried the different gas, still no luck
Old 09-25-2012, 10:55 PM   #18
I see you're a 2008. How many miles are on it?
I'm just guessing maybe a fuel issue such as a dirty injector perhaps? Also very well could be a boost leak. Stock Charge pipes?
Zander916 is offline   Reply With Quote
Old 09-26-2012, 05:49 AM   #19
Iam Broke's Avatar
Images: 4
Run a compression check, sounds like a dead cylinder. (90 psi or less)
Iam Broke is offline   Reply With Quote
Old 09-26-2012, 06:14 AM   #20
Nothin Stock
Images: 4
i change my plugs every year, the last coulpe mornings iv been get misfire after driving 15-20min, it looks like its time for me again
gotboost?17 is offline   Reply With Quote
Old 09-26-2012, 06:16 AM   #21
Nothin Stock
Images: 4
btw i thought misfire cels dont go away?
Old 09-26-2012, 06:29 AM   #22
Images: 20
Quote:
They do go away unless ECM detects more than 40 misfires (I believe) and then it
stores that info in the dtc's.
Cherry GT is offline   Reply With Quote
Old 09-26-2012, 10:06 AM   #23
It has 48000 on it, and yea stock charge pipes.
Quote:
I really hope not, or the cars gone.
Old 09-26-2012, 01:59 PM   #24
Images: 16
this^^^^
AND when was the fuel filter last changed?
-easiest way to check the coil pack is to move the pack from the cylinder that is misfireing to another cylinder, take that one and put it on the misfiring cylinder. If the misfire moves to a different cylinder than chances are the coil pack is toast.
Old 09-26-2012, 02:02 PM   #25
Images: 16
this^^^^ pic?
Thread Thread Starter Forum Replies Last Post
No power and a flutter sound turbochargedss2012 2.0L LNF Performance Tech 7 03-20-2016 12:30 AM
P0171 after zzp stage 3 kit instal. Sean Cummings Problems/Service/Maintenance 33 10-15-2015 12:21 AM
HELP please 717ssbalt 2.0L LNF Performance Tech 9 10-02-2015 04:01 PM
2.2l heat sensor going in and out please help jmelton327 Drivetrain 2 09-26-2015 10:04 PM
Porcelain piece broke off a spark plug and fell in the cylinder; LNF running weird Getaway_Driver Problems/Service/Maintenance 41 09-08-2015 09:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
