Secondary O2 Sensor CEL
I did the propane bench test on the sensor, and it didn't rise much beyound .1 volts. Hopefully replacing the sensor will make quick work of this.
You wouldn't happen to know where the sensor feeds into, would you? I had a look at the connector today and the rear of the plug looked like it was exposed from the conduit. Its not necessarily broken, but it'd be nice to confirm.
Really appreciate having somebody else to bounce ideas off of, by the way. Thanks.
The back of the connector being exposed isn't an issue. There are seals on each wire in the connector.
Good luck getting the evap to ready. The evap monitors rarely set on these cars. Most emissions standards actually allow for 1 monitor to not ready though, but that's here in the states. I'm not at all familiar with Canadian emissions.
Like I said earlier. Good luck getting that monitor to ready. I have not seen one LNF with an evap system monitor readied. Even bone stock cars on a stock tune.
