SS boost problem - Cobalt SS Network
Technical Discussions ONLY!
Thread Tools Search this Thread
Old 10-19-2012, 07:57 AM   #1
SS boost problem
Posting this for a friend but pretty much the car immediately goes full boost if your on the throttle at all. It's either your off the gas and at no boost (doesn't even go into vacuum) or if your at any throttle it tries to full boost. He said its throwing a code but haven't scanned it yet. Any ideas?
Magz_rule is offline   Reply With Quote
Old 10-19-2012, 08:09 AM   #2
Code would really help here.
ULWizSS is offline   Reply With Quote
Old 10-19-2012, 12:55 PM   #3
Images: 1
My suggestion is to scan for the code. It's probably the turbo-overboost code, but it would be nice to know what it says.
Until you can get to that, check you waste gate rod, waste gate solenoid wiring connection, the vac source tubing from the coldside to the vac solenoid, the vac solenoid wiring connection, and the vac tubing going from the vac solenoid to the BPV, and condition of the BPV.
This is the waste-gate rod (this is a mitsu turbo, so it looks slightly different, but you get the idea):
This is what the waste-gate flap looks like, but you won't need to look at that:
This is your waste-gate actuator, source-tubing, and actuator tubing:
SSlobalt is offline   Reply With Quote
Old 10-19-2012, 01:13 PM   #4
Hockeyman's Avatar
Images: 35
sounds like a fun driving experience
Hockeyman is offline   Reply With Quote
Old 10-20-2012, 12:42 AM   #5
rukkee's Avatar
Images: 76
Ive heard of wastegate rods coming lose .....maybe ur is stuck shut or the Wg actuator is unplugged or junk?
rukkee is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
No power and a flutter sound turbochargedss2012 2.0L LNF Performance Tech 7 03-20-2016 12:30 AM
KMO43 Oct FCOTM KMO43 Front Page News 34 01-12-2016 12:01 AM
HELP please 717ssbalt 2.0L LNF Performance Tech 9 10-02-2015 04:01 PM
CEL for Air/Fuel ratio DocSvensk 2.0L LNF Performance Tech 7 09-27-2015 02:24 PM
07 lsj-t problems gen 3 build Adiaz1ss Problems/Service/Maintenance 4 09-26-2015 11:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
