Vac no Boost
Vac no Boost
Alright guys, here it is.
1.I got a loud howl coming from under the hood that only "howls" as i watch the boost gage go from negative to just below 0. and does NOT build boost....when it should
2. have some white smoke coming out of the exhaust, smells like oil.
3. i have zzp charge pipe upper and lower and zzp IC and the connections were good.
4. at idle, no "howl" but on engine start-up with the higher idle get the louder "howl"
5. I'm not getting ANY misfires but getting the MAP sensor codes.
I'm guessing because the turbo was already leaking oil into the upper charge pipe(not much)
that the turbo has a broken impeller, letting this oil leak into the hot exhaust and burn out.
currently running zzp upper and lower charge pipes and IC 3inch exhaust, catless downpipe, no res, no muffler. and still rocking the K04 stock turbo at 25psi
i do NOT have a 3 bar MAP
only thing i can do i think at this point is just to take it into a shop to have it checked out unless you guys have insight into this issue.
thanks guys, take care
Yes but the best time for a video would be tomorrow morning if you don't mind waiting. I still have to drive kids to and from school so the engine will be warm till then.
I was gonna say lol. When I first heard that in my car, I also noted that it sounded kind of like metal grinding sound. I didnt realize that the howl was actually air sucking into the turbo through the intake. Had no idea it would be that loud. Coming from an N/A car with an intake, its completely different sounding. With that said and you saying you have a K&N intake, Id say the howl sound is not a symptom of your problem and is actually normal.
As for the no boost thing. Any CELs? What CELs do you have
I am fully aware of the sound that it makes when it is not broken this is a lot different. I agree a na sounds a lot different but trust me, this is a broken sound
