Zeeky420 build thread
So I figured I should start a build thread since my car is starting to see some progress my goals are full build on this one. So far right now I'm making 310hp 344tq on stock turbo and 93 with full bolt ons and tune. I'm going to build car for top speed 1/2mile runs. I'm in process on having lnfwagonss build my f40 trans with Lsd I already ordered zzp conversion kit I just ordered my koni shocks and I already have rear cabs I going to buy LCABS YYZ springs and get Powell to cut some old housing I have to assemble I also already have Powell's xxx sway bar I be getting more from Powell later. After I get some of these things done I plan on 257 turbo kit and I want to have f40 in and 257 in by July for wanna go fast here in VA. I will be putting pictures up later when wheather gets better. I think that's everything so far thanks
For sure you should I decided to use wavetrac LSD instead of quaife on this one because i want something different and there's a lot of good being said about them
Ya that's a good chunk of change you would be spending LSD , parts for trans upgrading bolts if you want to you would have a $1800 Bill just for putting in LSD and shipping back
So I got the opels in yesterday and zzp f40 kit is finally on way after over a month wait for f40 axles or something which isn't really a problem cause I'm not putting trans in to about May and I sent struts to Powell racing with koni's to be put together with the springs and also ordered team dynamic wheels 17x9 but won't see those for couple months but I can't wait I'm trying to be ready for wanna go fast in July I'm hoping everything comes together
Turbo kit is ordered yesterday but waiting on turbo to come in also I should have trans in by end of month I was looking to install trans and turbo same time in june also was going to put upgraded fuel lobe at some point
Ya I used a wavetrac Lsd which Jason thought would be a better lsd because of it's full locking all the time so even if the wheels are in the air they are both locked and also locking on deceleration
