zfr turbo
#51
The 71 is not too big for the LNF. That is false it spools fast and makes great power
#52
Word of warning, when I bolted my 7163 to my LDK's exhaust manifold, it didnt look like it was sealing on one side when I ran the nuts down. On closer inspection the turbo housing was making contact with the exhaust manifold preventing it from bolting up. It took a lot of on/off/on/off sanding and grinding off both the turbo and manifold to get a proper fit. Thank goodness the engine was out of car, I may not have seen the small gap at all and just torqued it down. My suggestion would be when installing the turbo in car, snug it lightly and look all around. If you have to grind its not that much more work to pull the manifold and do it outside the car so you can see and sneak up on the gap needed if you encounter the same issue.
#53
#54
#58
It is. And others are throwing on the 257s. But being an EFR is spools fast and works very well on our car. It needs little to no ramp and will make more hp than the 67 that is why I recommend it
#59
i just got my 7163 put in on my LNFand waiting on a tune.
Im FBO except 3" exhaust and BOV.
Stock internals and stock bottom end on GMPP clutch and LNF flywheel.
Currently at 100k mikes.
Would fueling be recommended next? Opels? Stage 2 cam?
how much can I make safely with boost ramp?
#60
I just got my 7163 put installed on my LNF and now just waiting on a tune.
I'm FBO except 3" exhaust and BOV.
#62
