ZZP Builds The Best LNF Mod Ever!
Nickisreal (12-16-2019)
Yes, this is an EFR based turbo. It has an unbelieveable list of features:
Ball bearing
Water cooled
Billet wheel
Extended tip
Stainless exhaust housing
Titanium/aluminide exhaust wheel
Built-in recirc bypass
Built-in wastegate
We took all of this and added:
Bolt-on to LNF manifold
LNF exit for factory O2 housing
Re-designed wastegate actuator bracket for use in this application
Adapter fitting for factory LNF oil inlet hose
This setup uses our off-the shelf charge tubes, intercooler, downpipe, etc... It also has a stock airbox and our silicone intake coupler with a slight modification.
The best part about this setup is the simplicity. I got the turbo on the car and strapped it on the dyno. The first pull was 411whp, the 2nd pull was 473. The 3rd pull was 487, then 489. Then I had to make some adjustments to the wastegate actuator to get more boost and the next pull was 509whp. Looking at the dyno sheet, you can see 25psi at 3400 RPM, so lag is not an issue either. All in all, I'm pretty happy with this project so far.
Ball bearing
Water cooled
Billet wheel
Extended tip
Built-in wastegate
