2007 LSJ idle issue with AC on
Old 08-25-2016, 03:01 PM
Sean Cummings's Avatar
Ok here is what is happening, with AC on the car will surge when coming to a stop, it will recover and idle fine after a few sec. The car will not do this with ac off. The car has been tuned by Zzp a few times bit it still does it. My mods are in my sig. Car runs fine except for this.
Old 08-25-2016, 05:52 PM
Supercharged06SS's Avatar
I always had that problem in my LSJ. It got worse when I switched to 80s and e85. I've read the same thing other places, that the car runs like crap with the AC on. But for some reason my lnf runs perfect with AC on
Old 08-26-2016, 01:57 AM
Thanks for the reply, it only started after the mods and tune
Old 08-26-2016, 06:03 AM
It probably has to do with the tune as long as you dont have any intake air leaks
Old 08-26-2016, 07:20 AM
Administrator
Administrator
Staged07SS's Avatar
2007's had an idle hunt issue. It's in the tune.
Old 08-26-2016, 09:06 AM
I have HP tuner where is the ac follower settings? Or when would I look at this and fix it?
Old 08-26-2016, 12:49 PM
Rent me! per hour
Area47's Avatar
add a global 5 to the ac table in torque management. {first tab}
Old 08-26-2016, 01:21 PM
Meaning add 5 over whole chart on the engine tab under torque management tab?
Old 08-26-2016, 02:20 PM
So if my idle hangs with the AC on i should do the opposite? Lol
Old 08-26-2016, 04:35 PM
Rent me! per hour
Area47's Avatar
correct.
the LE5 is a different story.
Old 08-27-2016, 04:30 PM
mrbelvedere's Avatar
the man speaks
Old 08-27-2016, 08:31 PM
Doing the global 5 didnt help any, still the same, any other options?
Old 08-28-2016, 11:22 PM
Sharkey's Avatar
i tried it on my car, added 5 to the whole table. idle is far better, but not perfect yet.
Old 08-29-2016, 02:52 PM
Rent me! per hour
Area47's Avatar
There is a few other things that come into play. Who did the fuel injector scaling? You ever clean the throttle body? Have you logged fuel trims?
Not everything is an easy fix.
Old 08-29-2016, 08:46 PM
Zzp did fuel incector pulse, the TB was replaced earlier in the year due to it failed. I only have the issue with AC on. The idle with it off is silky smooth. I have logged the car numerous times and cant see anything out of ordinary
Old 08-30-2016, 01:00 PM
Rent me! per hour
Area47's Avatar
if the scaling is off, the whole tune is off. This is the point i was trying to make. There is some timing table manipulation that can be done as well to take care of it.
jdeshong
04-19-2016 02:46 PM
Chris06CobaltSS
04-18-2016 04:18 PM
SECRETARIAT
02-22-2016 11:35 AM
cavfiredesire
02-10-2016 10:19 PM
Quick Reply: 2007 LSJ idle issue with AC on
