pulley
Old 01-19-2011, 08:04 PM
ABSOLUTE GHOST's Avatar
pulley
I was woundering what next size pulley i could get other then the stock one??
Old 01-19-2011, 09:31 PM
CTcar's Avatar
depends on how much money you have to throw around. You could go slightly smaller 3" with injectors, belt, tune and be around $300, or a little smaller 2.8" 60# injectors, belt, plugs tune, h/e etc and be $500-$600. If this is your first mod, go for cold air intake or exhaust set up.
Old 01-19-2011, 09:42 PM
ChevyRockstar's Avatar
what injectors do you have, you shouldn't be dropping pullies if you can't feed the fuel
Old 01-20-2011, 12:19 PM
The only mods i did was a intake so far, I wasnt sure if i could put a different size pulley without buying new injecters.
Old 01-20-2011, 02:06 PM
CTcar's Avatar
It's better to go with a whole stage kit, so you get everything you need. But if you pulley down, that means more air coming in, so you need more fuel to match
Old 01-21-2011, 03:26 PM
M.K. SS's Avatar
but with an intake that also means your pulling in more air so this will obviously change the afr's. im a newb at this so please be patient with me as this is only a question. since your pulling in more air with the intake, do you automaticly need a tune or can you run an intake safely?
Old 01-21-2011, 04:33 PM
CTcar's Avatar
You can safely run an intake without a tune. Before I was tuned i had an intake and every now and then I would get a check engine light, but it would go away. It was always a too lean code.
Old 01-21-2011, 04:35 PM
M.K. SS's Avatar
^^^ thank you very much for clarifying that!
Old 01-31-2011, 07:20 PM
now with a stage 2 kit will i have to get my car tuned?
Old 01-31-2011, 10:53 PM
CTcar's Avatar
Yes you will. Many people go with a stage kit that comes with a basic tune, and then get custom tuned later on which can get some extra power over the generic tune.
10-20-2015 09:56 PM
SSLOW06
10-01-2015 07:21 PM
patooyee
10-01-2015 01:07 PM
09-30-2015 07:22 AM
ChrisTutoki
09-24-2015 08:39 PM
Quick Reply: pulley
