crusie control problem any ideas??
Old 01-31-2011, 12:20 PM
ss slobalt's Avatar
i have a 06 ss and everytime i try and set the cruise control it will flash cruise engaged and then go off. i havnt had a huge problem to recently where when i set it it wont even come on. the orange light will light up on the steering wheel but it wont set at all. does anyone have this problem or know how to fix it cuz its so annoying!! thanks guys!!
Old 01-31-2011, 12:22 PM
rekameohs_nire's Avatar
Mine hasn't worked for months. In for some info
Old 01-31-2011, 12:24 PM
quikdcride's Avatar
hahaha yea man this happened to me the night before i was leaving on a 500 mile trip and it kinda freaked me out. also happens when i drive in the snow
idk what it is but all you have to do is disconnect the battery for like 10 minutes and just reconnect and you should be good to go
Old 01-31-2011, 12:29 PM
SS_NH's Avatar
do any of you have led third brake lights?
because that will do it.
JERMzSS's Avatar
This might be a long shot but make sure all your brake lights are working....mostly the 3rd brake light. I saw a Ford once a few years ago had this problem and it was the 3rd brake light. Crazy I know but it fixed that car.
Old 01-31-2011, 12:32 PM
SS_NH's Avatar
its because when your third brake light comes on, it kicks your cruise off.
so if you have a light or two out or have leds with no resistors, then it keeps thinking your third brake light is on and no cruise.
Old 01-31-2011, 12:35 PM
I don't have a third brake light lol
Old 01-31-2011, 12:36 PM
SS_NH's Avatar
at all? that's why... lol.
JERMzSS's Avatar
lol that could be why it no worky
Old 01-31-2011, 12:46 PM
That's why lol
Old 01-31-2011, 12:49 PM
CleanCut's Avatar
I had this prob too.. Mine is a 06 and it's been happening since I bought the car.. What I do is wiggle the clutch peddle till it engages.. If I hit something hard like a pot hole it disengages but I just deal with it
Old 01-31-2011, 12:57 PM
CanadianCobalt's Avatar
Reset your batteries if you have a third brakelight, if you push your clutch a certain amount of times without changing gears it disables it (Maybe driving slowly in snow, or on traffic, etc.)
Joel
Old 01-31-2011, 01:01 PM
alleycat58's Avatar
Somewhere in heaven my driver's ed teacher is bawling unconsolably.
Your clutch switch is probably bad.
Joel
If you press the clutch AT ALL it's supposed to disengage. If it's not disengaging there's a problem.
Old 01-31-2011, 01:29 PM
Disengange and disabling are two different words. Pressing the clutch a certain amount of times without shifting the gears, not while cruising disables the cruise control feature by setting an invisible code. Reset it by removing your battery cables for a few minutes.
Joel
Old 01-31-2011, 02:27 PM
alleycat58's Avatar
Joel
Wow. A car that senses when drivers fail at driving. I love it!
Old 01-31-2011, 03:23 PM
quikdcride's Avatar
im telling you man disconnect the battery for 10 minutes and reconnect it and it will work
f#ck what all these other people are telling you
ive done it like 8 times
Old 01-31-2011, 03:29 PM
sternerG85SC's Avatar
who needs cruise control? i'd rather hit the gas
i tried using mine awhile ago and it wasnt working. my 3rd brake light works. so who knows lol.
Old 01-31-2011, 03:43 PM
alleycat58's Avatar
I haven't used cruise in my Cobalt in....jeez.....YEARS. But I made a road trip last June in my other car that doesn't have cruise. 550 miles of all highway and no cruise control sucks *****.
Old 01-31-2011, 03:57 PM
G11
G11's Avatar
mine worked when it was stock....then i put stage two on and it didn't work....then i am to where i am now and it works...
almost wanna say the gm stage 2 programming is funny...oh wait it is haha!
Old 01-31-2011, 04:11 PM
A man that's never been stuck in traffic apparantly.
Happened to me following an accident where I could not go fast enough to get out of first.
Joel
Old 01-31-2011, 04:23 PM
alleycat58's Avatar
Joel
Woman that's been stuck in traffic many a times.
Didn't think cruise would work in 1st anyway. I'm thinking more of people that put the clutch in at highway speeds....multiple times. I've only met a couple people that do it, but they're out there. My best friend's boyfriend is the worst offender I've met. ANYTIME he's going down the slightest downhill section of road, car stays in gear, clutch goes in. "But I'm coasting!" "Then do your TOB a favor and throw it in neutral!"
Old 01-31-2011, 04:30 PM
Joemaster70's Avatar
my CC only works in warm weather
Old 01-31-2011, 04:35 PM
ss slobalt's Avatar
i have the factory third brake light and it worked fine and i noticed a white knob looking piece above the clutch and when you press the clutch it moves it up. could it be sticking somewhere up there and if so is there any safe way to pull it out. and i changed my brake lights to the smoked leds but my cruise stopped working before i changed them out
Old 01-31-2011, 04:37 PM
ss slobalt's Avatar
there has to be a problem with it if youve done this like 8 times?
Old 01-31-2011, 04:49 PM
Cruise doesn't work in first. You have to be going above 50kmh to use cruise control. I'm not talking about clutching while cruise is on. Just anywhere in general like the situation I was in.
Joel
Quick Reply: crusie control problem any ideas??
