ABS light on help - Cobalt SS Network
2.0L LSJ Performance Tech 205hp Supercharged SS tuner version. 200 lb-ft of torque
Technical Discussions ONLY!
Thread Tools Search this Thread
Old 01-30-2011, 12:51 PM   #1
ABS light on help
hey, i alrdy tried a search but couldnt really find what i was looking for. anyway last night i got a "ding" noise and my ABS light came on. i dont feel any difference in braking or anything, anyone have any idea what it could be?
YEW FAIL is offline   Reply With Quote
Old 01-30-2011, 01:11 PM   #2
It could be alot of things, you need to get the codes pulled to see if it is spitting one out (which it should be).
rnjmur is offline   Reply With Quote
Old 01-30-2011, 01:12 PM   #3
Quote:
does a regular scanner pick this up or does it have to be a special one?
Old 01-30-2011, 01:15 PM   #4
Images: 72
Quote:
It MIGHT I dont know for shure, but I think the regular scanner only gets Powertrain codes.
insylem is offline   Reply With Quote
Old 01-30-2011, 06:32 PM   #5
Alot of times it depends on the problem. If it is a wheel sensor a normal scan should pick it up. I think you need a tech 2 to access the ABS module.
Old 01-30-2011, 09:40 PM   #6
mrbelvedere's Avatar
you can go to autoparts and get an abs scanner
mrbelvedere is offline   Reply With Quote
Old 01-30-2011, 09:55 PM   #7
You wouldn't be able to tell a difference in braking unless you were in snow or slammed on your brakes.
HyperMuffin is offline   Reply With Quote
Old 01-30-2011, 10:32 PM   #8
G11
check your wires going to the wheel speed sensor...mine got corroded and broke just out of no where...had to get a new hub assembly to replace it
G11 is offline   Reply With Quote
Old 01-31-2011, 09:17 AM   #9
JshLnsctt's Avatar
Images: 4
Mine came on yesterday too, thinking its probably a wire, though I'm going to try to get to autozone or somewhere to have them read the code for me.
JshLnsctt is offline   Reply With Quote
Old 01-31-2011, 09:36 AM   #10
its your speed sensor in your wheel..mine did the same thing and i took it in and had to have the "speed sensor" in the back replaced and it never came back
carstedt is offline   Reply With Quote
Old 01-31-2011, 02:26 PM   #11
JshLnsctt's Avatar
Images: 4
When I changed my tires I noted on my car that one of the lines had a few slices in it from the mounting clip, I'm assuming that's where my problem lies.
Old 01-31-2011, 09:03 PM   #12
Images: 11
Quote:
LMAO.....GET IT SCANNED thats the first step to a proper diagnostic!
if u start swapping parts without even knowing the problem....u better have deep pockets.
if u dont have a scanner handy, at least visually inspect the system.
ThiZo_19 is offline   Reply With Quote
Old 01-31-2011, 11:02 PM   #13
car was under warranty and i also scanned it and inspected it...good try tho
Old 01-31-2011, 11:34 PM   #14
My ABS light has been coming on every time the road gets wet. I figure it's a sensor and the dealer wants $90 to scan it and if it's under the drivetrain warranty it's all covered, if it isn't then I have to pay.
Guy at Autozone said he couldn't scan chassis codes, if that helps.
Davy_Baby9 is offline   Reply With Quote
Old 01-31-2011, 11:41 PM   #15
Images: 32
Common problem I guess, mine comes on and off routinely. Im gonna thoroughly check it out when I swap my springs
BLue NoTe is offline   Reply With Quote
Old 01-31-2011, 11:45 PM   #16
Images: 5
My popped on after racing from a dig with bald tires and spinning till 50, I drove home and turned the car off and on again and it was gone, But I assume you've already done that haha
Phyrric is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Let down the cobalt community on this one. RaginChopsuey War Stories 16 10-27-2015 02:27 PM
"supercharger Collant" leak brandon04 Problems/Service/Maintenance 46 10-21-2015 08:04 AM
Awesome Suede Seat Cleaner dennis69 Appearance 9 10-20-2015 05:49 PM
WTB many lsj bolt on parts. z28addiction Wanted - What to buy - All categories 0 09-28-2015 01:03 AM
GBRunner24's October FCOTM GBRunner24 Featured Car Showcase 3 09-26-2015 07:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
