Forum Jump Gallery Social Groups VBgarage Videos Chat Link To Us Decals Site Map Contact Us
Cobalt SS Network Forums
The Cobalt SS Network is the leading resource for all Chevy Cobalts and related Delta
platform cars. Registered users do not see the above ads. Please Register - It's Free!
Supporting Vendor Index | Vendor Forums
Go Back   Cobalt SS Network > Engine Technical Discussion > 2.0L LSJ Performance Tech
2.0L LSJ Performance Tech 205hp Supercharged SS tuner version. 200 lb-ft of torque
Technical Discussions ONLY!
All About the LSJ
This is a discussion on All About the LSJ within the 2.0L LSJ Performance Tech forums, part of the Engine Technical Discussion category; I got some emails from guests asking about the LSJ, so lets get some info up. What makes this engine ...
LinkBack Thread Tools Search this Thread Display Modes
Old 04-10-2005, 02:25 AM   #1
Site Founder
JonyyB's Avatar
Member #: 1
Check out my gallery  Check out my vbgarage
All About the LSJ
What makes this engine good, what needs improvement, and what are some of the mods that can put this engine in the 13’s?
Redline and SS guys, what is your experience with the LSJ?
2.0L ECOTEC Supercharged DOHC LSJ
Displacement (liters/cu. in.): 2.0/122.0
Bore & stroke (in.): 3.4x3.4
Bore & stroke (mm): 86.00 x 86.00
Compression ratio: 9.5:1
Block material: cast-aluminum
Cylinder head: cast-aluminum
Valves per cylinder: 4
Ignition system: electronic
Lifters: hydraulic
Cam drive: chain
Alternator rating (amps) 105
Battery (SAE rating, cca) 525
Recommended unleaded fuel 87 octane 91+ octane (note1)
Redline (RPM) 6500
Horsepower/kW @ engine RPM 205/152.93 @ 5600 RPM
Torque (lb.-ft./N-m) @ engine RPM 200/271.16 @ 4400 RPM
note1: Cobalt SS Supercharged will operate with 87 octane unleaded fuel. However, a power loss will be noticeably felt by the driver.
chevy.com
__________________
CobaltSS.net is now owned and operated by Internet Brands. All questions should be sent to Robb M. or speedlimit
06 Cobalt SS2 — See my VBGarage for more info/pics.
JonyyB is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 04-12-2005, 12:14 AM   #2
Member #: 880
From what I hear people are already hittin 13s w/just homemade intakes and generic mufflers! Imagine what could be possible w/ an designed and tested aftermarket intake system from intake to TB to manifold, a boost pulley and header back exhaust!
CoBIZZLE is offline
Old 04-12-2005, 02:40 PM   #3
Member #: 1013
what is the redline for the NA motor?
__________________
tiny is offline
Old 04-27-2005, 10:42 AM   #4
Member #: 1472
EMS?
Who's developing?
Will AEM?
Everyone will be Pi$$ing in the wind until then.
Only Ecotec I've Dynoed was a Redline @ 210WHP w/ K/N.
Chrisxotic is offline
Old 04-27-2005, 03:25 PM   #5
Member #: 38
Quote:
and 13's redlines drivers are barily hitting 14's majority of them are in the 15's. not dissing but its true. probably 4 - 5 owners have hit 14's all others are 15-16 range. i know its the driver but i just find it hard to believe
imo what it will take to hit 13's will be, CAI, after market header, definatly the LSD. if the SCDYNE header gives the car 25+whp then that should be enough to get the ss into the 13's. possibly just an intake with a good tune will let it hit 13's.
Eddie is offline
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
vBulletin copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
