belt tensioner problem. help needed
i cant get the tensioner to loosen up. the open end wrench keeps sliding off! how else can i get the belt off to take my supercharger??
What size wrench are you using? Make sure you get it all the way on there, it doesnt really want to fit, you have to push it on there pretty good. Then just push it toward the back of the car.
I know you got it off but there is another way, take a torx bit and use the screw in the actual pulley to depress the piston. Or the Pulley Boys tool
When using an open ended wrench, it helps to use on thats squared rather than one that is rounded.
agentirons
10-16-2015 02:11 AM
