Best setup for factory Supercharger?
Old 10-22-2016, 10:34 PM
BigMajin's Avatar
I was thinking about getting a TVS supercharger but all the upgrades that has to go along with it going to break pockets. I want to know what I need to max out the factory Supercharger HP and TQ numbers running 93 pump gas? I was given this list from ZZP far as the TVS upgrade goes.
http://zzperformance.com/ecotec/engine/ecotec-ported-head.html
http://zzperformance.com/ecotec/camshafts-valvetrain/lsj-performance-cams.html
http://zzperformance.com/ecotec/camshafts-valvetrain/82-ecotec-valve-springs-and-titanium-retainers.html
http://zzperformance.com/ecotec/air-intake/ls4-throttle-body-for-lsj.html
http://zzperformance.com/ecotec/air-intake/zzp-3-cobalt-cold-air-intake.html
http://zzperformance.com/ecotec/intercooling/zzp-lsj-s3-cobalt-heat-exchanger.html
http://zzperformance.com/ecotec/intercooling/zzp-lsj-dual-pass-intercooler-plate-kit.html
http://zzperformance.com/ecotec/intercooling/option-b-for-dual-pass-ic.html
http://zzperformance.com/ecotec/intercooling/option-b-reservoir-bracket.html
http://zzperformance.com/ecotec/fueling/siemens-60-injectors-4.html
http://zzperformance.com/ecotec/electronics/zzp-1-0-lsj-pcm.html
Old 10-22-2016, 10:46 PM
Haven07's Avatar
Youuuuuuuuu need to research....this has been covered many times....
I personally wouldn't bother trying to max the stock m62
Old 10-22-2016, 10:49 PM
BigMajin's Avatar
Well what's the minimum for a TVS to be close to 300hp?
Old 10-22-2016, 11:00 PM
Haven07's Avatar
Take a look at this thread
https://www.cobaltss.net/forums/dyno...2015-a-304260/
Old 10-23-2016, 12:08 PM
jdbaugh1's Avatar
Originally Posted by BigMajin
Pretty much any supporting mods you need with a maxed out M62 are the same mods you need with a TVS. The most expensive part is the TVS itself.
Old 10-23-2016, 12:11 PM
cluelessk's Avatar
Stop encouraging these type of posts.
It's been covered. 90% of the time he OP doesn't even go through with it.
Old 10-23-2016, 12:35 PM
mrbelvedere's Avatar
Ecotec Parts Ecotec Ported Head do not need
Ecotec Parts LSJ Performance Cams do not need
Ecotec Parts 82# Ecotec Valve Springs & Titanium Retainers
Ecotec Parts LSJ LS4 Throttle Body do not need
Ecotec Parts ZZP 3" LSJ Cobalt Cold Air Intake do not need
Ecotec Parts ZZP LSJ S3 Cobalt Heat Exchanger do not need
Ecotec Parts ZZP LSJ Dual Pass Intercooler Plate Kit do not need
Ecotec Parts Option B for Dual Pass IC do not need
Ecotec Parts Option B Reservoir Bracket do not need
Ecotec Parts Siemens 60# Injectors (4)
Ecotec Parts ZZP 1.0 LSJ PCM
all you really need is the blower injectors and a tune
Old 10-23-2016, 03:14 PM
BigMajin's Avatar
LOL thx I like the response in red. So I do need the valve springs? You didn't mark it.
Old 10-23-2016, 03:20 PM
BigMajin's Avatar
I am definitely going through what I say. I have a 14 GLI Autobahn that I spent 4k cash in performance mods on at one time. I just bought the Cobalt for 4k cash as well last week and will spend the money needed for upgrades to be faster than my GLI. So dead serious...
Bruceee (10-24-2016)
Old 10-23-2016, 06:32 PM
if you want to stay blown get a tvs put the car on e85 and a set of 80lb inj tune it enjoy
Old 10-23-2016, 08:27 PM
BigMajin's Avatar
Has to be 93 only. No E85 near me.
Old 10-23-2016, 10:36 PM
Haven07's Avatar
Then your gonna need meth or consider going turbo
Old 10-24-2016, 09:25 AM
Stumpalump's Avatar
I would walk or ride the bus before I owned anything in Memphis. That rats nest brags when car jackings are less than 70 per month. Sell it and move. You do not know what you are missing in life and a fast car won't solve it there. Mr. GDS advise will get you away the fastest and cheapest and the rest of the stuff will get you a little further.
Old 10-24-2016, 05:34 PM
BigMajin's Avatar
I stay in Suburb of Memphis. And car jackings are rare. Mostly murder here. I am a Shelby County Officer so simply don't directly deal with that issue. Car burglary yes jacking folks for rims and radios if it's in plain site. I already have a fast 14 GLI no car jacking and same for the cobalt.
Old 10-24-2016, 08:25 PM
no you don't need valve springs if 93 is your only option then keep it on a 2.9 pulley you can always mix a couple of gallons race fuel to up the octane
Old 10-24-2016, 10:19 PM
BigMajin's Avatar
TVS 2.9 safe to run on factory cooling?
Old 10-24-2016, 10:25 PM
shadowfaxss's Avatar
The complete GMPP Stage 3 setup with nitrous! You'll achieve 300+. Incidentally, I have most of the components I have not sold yet.
GM Stage 3 and Nitrous for Sale
Old 10-24-2016, 10:27 PM
BigMajin's Avatar
No nitrous here...
Old 10-25-2016, 07:22 AM
the gm stg3 kit is designed to be used with 42lb/hr injectors(way to small for a tvs) a 50hp dry shot and you will not achieve 300+ plus hp on the kit
Old 10-25-2016, 12:58 PM
Haven07's Avatar
I would at least do a option B mod. Everything else helps out but imo the option B mod is one of the most important mods for a supercharged lsj
Old 10-25-2016, 02:05 PM
Administrator
Administrator
Staged07SS's Avatar
Yes it most certainly will.
I saw a box stock GM Stage 3 50 shot dyno back in the day, and the car made 290whp and 305wtq.
With additional exhaust mods, that car would have exceeded 300whp on the GMS3 tune and nitrous w/ M62.
Hell, I made 299+whp with the GMS3 kit w/o nitrous, yes I had a ported head, cams, and H62, but to say the kit won't produce 300whp is just not true.
I wish I ended up installing the nitrous jumper wires and kit on my car to show what it really could have done.
The following 2 users liked this post by Staged07SS:
Micro (10-29-2016), shadowfaxss (10-25-2016)
Old 10-25-2016, 02:06 PM
Administrator
Administrator
Staged07SS's Avatar
OP, the best setup is all a matter of opinion....
There is the best setup for cheapest price, best setup for max power, best setup for safe useable power etc.
You need to decide exactly what you want, and go from there.
The setup I had was for all around efficiency and in my opinion, was one of the best ways to go.
Old 10-25-2016, 05:27 PM
Have to agree. I dyno'd at 273 with the 100 octane mode and was running snow tires at the time. The 100 octane mode coupled with the dry shot should net 300. I do have the dual pass, etc, etc. but no engine internal work done.
Old 10-25-2016, 05:32 PM
BigMajin's Avatar
I will buy the TVS in February. Along with all supporting mods needed all at once. That's just how I do things. I just need the 300+ horsepower setup 93 Octane only! with a TVS. Without porting anything...
Old 10-25-2016, 05:43 PM
jdbaugh1's Avatar
Methanol injection kits are not that hard to install. I would do that while you are under the hood because it is definitely worth it. I went from running 12 degrees ignition advance on 91 octane (that's all I can get besides race gas) and now I am running 24 degrees ignition advance with 1:1 mix methanol and distilled water with two 3-gph nozzles. Huge difference.
