Camshaft questions/ideas
So, I'm a week away from being able to purchase a set of Comp Cams from Summit or TurboTech but I still have a few things holding me up.
First off, some contradictory information that I need to get cleared up. Comp, who manufactures the cams I want to buy, states their Xtreme Energy cams will work in both a 2.2 and 2.0 eco. If you've ever seen the difference between the two cams in the engines, you'll notice that the exhaust cam in the 2.2 is shorter than the intake while the LSJ, they're equal longer length. Pretty much everyone has speculated that the two are not interchangable because of the LSJ cam sensor positioning.
Now, GM has released a cam info sheet here and states the 2006 model year 2.2 and the 2006 model year 2.0 are indeed interchangable as far as cams go. However if you read at the bottom, it states the GMPP race cams are 2.2 spec and will physically fit the LSJ, but won't work with the cam sensor. WTF!?
So I guess my question is, are the Comp Cams equal length, and if they're not, is the cam position sensor mounted to the intake cam or the exhaust cam? Would it make a difference if the exhaust cam is indeed shorter, would it still be usable in the LSJ?
Anyone have Comp Cams that care to enlighten me?
Last edited by Witt; 01-21-2007 at 05:14 AM. Reason: More info found, corrected inaccuracies
I'm pretty sure that those cams are not interchangeable, but I'm not 100% sure. Take a look at the link in my sig., JBP is having a Group Buy on their Tri-Flow cams. The price has been reduced dramatically, they are currently cheaper than the Comp Cams I believe.
Yeah Doc, thats the sheet I linked in my post I think. Even GM contradicts themselves in saying the 2.2 and 2.0 are interchangable but the 2.2 race is not. Comp is saying their cams will work in both and their resellers are saying they wont. So much misinformation.
I have a feeling I get to be a guinea pig next week. I can't resist the temptation to buy those Stage 3 street/strip cams - 222/224@.050 ftmfw. As far as the jbp ones, they're too mild of a grind for me and I'm not up for stroking lash adjusters.
Here what i dont understand...why is everyone lining up to buy em with no proof of actual claims...aka...dynos? Last I checked their 2.4 results were lackluster...2hp at best.
And Al..I believe in teh cam sheet it only says the exhaust cams are swapable between the 2.2 and LSJ
Dan
Dan
Dan
Me thinks I'm pulling the cam cover off tomorrow and taking a look.
LSX RWD S/C conversion
I was going to buy the comp cams months ago. Until WOP told me that they were for the 2.2 only. I phoned Comp to clarify this because Comp's catalogue said they had 2.0 cams. Well they don't and if you want to get a set custom made you will wait 6 weeks for Comp to get around to it.
As far as JBP cams (which I am using) I am sure you can get Mev to do a grind to suit your needs.
Small update...Called Comp and they're under the assumption that the cam sensor that runs off the exhaust cam is internal to the cam, I tried explaining that it isn't and they said I have 2 options basically. One...send them pictures of my stock cams so they can verify their blanks are the same or two...buy their cams anyway and hope for the best but they would be non returnable.
OK, another update, got a hold of GM's drawings of the stock cams and sent those to Comp. They are saying they didn't recieve them and now they are telling me that some flange near where the hex drive is on the end of the cams are different. The drawing shows clearly otherwise and this is getting frustrating.
PS)I have NOOOO clue where Dan would get said drawing is he even did have them in the 1st place by the way.....
The comps exhaust is shorter I have seen the set. The cam drive is on our exhaust cam. Our cams are the same length. You cant use the 2.2 cam casue its to short as already stated to run the cam sensor. Get some blanks and have some ground for you. There are many shops out that that can do it and cost isnt really all that expensive to have a set made for you.
I have a feeling by the end of the week, I'm going to tell them to just make the damn thigns and I promise I won't return them.
I'm old school
No hex drive on the 2005 L61 intake. The drive pad is still there, but when take the cover off you can see the end of the intake cam and it has no drive connection.
Here's a question I haven't been able to answer. According to that new GM cam spec sheet that is linked above, it discusses how the LSJ cam and L61 cam (through 2006) are identical except for the timing. I have the GMPP adjustable cam gears, so I could twist my L61's to match the LSJ's once I have forced induction to reduce the valve overlap. Here's the question:
That sheet says the LSJ intake cam peak lift is at 100° ATDC intake with a duration of 196.5°, and the exhaust peak lift is at -115° BTDC exhaust with 191.7° duration. If you do the math, you see that the exhaust closes at 19.15° BEFORE TDC exhaust and the intake opens at 1.75° AFTER TDC intake, meaning there is more the 20° of NO overlap.
I know that has to be wrong. Somebody tell me what I'm doing wrong because it has been bugging me ever since that damn spec sheet came out.
I agree with the no overlap, I used one of those cam calculators off a website and plugged the values in and it came up with -15 degrees of overlap for the LSJ cam. Same deal with the jbp regrind.
As far as OEM 2.2 intake cam part number, dealer says its 90537667
My big question is whether or not Comp's intake blanks have the hex drive built in or not. They're starting to get sick of me calling.
Hey, I got a car I want to sell you. I can't tell you the year make or model, but it's only $10,000 and it's really nice. Do you want to buy it?
You need more than the opening, closing, lift, duration and lobe center specs to duplicate a cam, you need the lobe profile. If anyone really wanted to copy one they would just buy it and spec it out. But you do need this info to determine suitability for a particular application.
I can't possibly believe that anyone is buying them without the specs.
Maybe it's just me?
