?? car seems to studder/in 2nd gear??
Old 05-16-2007, 12:28 PM
LsJ2canada's Avatar
Hey guys.. last night on my way home when i put it into 2nd and step on it.. it seems to studder a little and if u let of the gas and give it some more it would studder bad then fart?? any ideas.. took if for a rip this morning all seems to be good?
Old 05-16-2007, 12:51 PM
vextc05's Avatar
maybe a misifre?
Old 05-16-2007, 12:57 PM
LsJ2canada's Avatar
i have stg 2.. i dont know if that has somthin to do with it ?? what should i be chekin?
Old 05-16-2007, 12:58 PM
vextc05's Avatar
did the cel flash on?? I had the same prob, but the cel flashed for 10 secs then turned off
beercan's Avatar
do you have an interceptor? .. if so scan for codes .. my car was throwing P0300(random cylinder misfire) for god knows how long and the CEL never came on
Old 05-16-2007, 05:20 PM
LsJ2canada's Avatar
no CEL light ... nothin..seems to be fine today
Old 05-16-2007, 05:54 PM
sealy's Avatar
bad gas?
what octane?
Old 05-16-2007, 09:26 PM
NoBalt123's Avatar
I have had a somewhat similar problem. And it ended up getting worse and worse. I think it is connected to stage 2. GM has told me that nothing is wrong, but I know that something is up, so I have contacted the BBB. Hopefully I will get some results from them.
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/boost-leak-40709/
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/help-dealership-trying-screw-me-44648/
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/anyone-stage-2-please-help-45828/
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/bypass-my-boost-surge-problem-45811/
Those are links to a few threads I started when trying to get to the bottom of the problem(which I still havnt done yet). Maybe the advice in those threads will help..
Old 05-16-2007, 10:17 PM
LsJ2canada's Avatar
you know think of it ... its a new tank of fuel.. i run 91 thats it...hmm thanks for ur help guys.. lets pray it stays away!!
dennis69
10-20-2015 04:49 PM
brett.higgins3
09-24-2015 09:51 AM
roadrunner132
09-19-2015 04:35 PM
ashalle2
09-16-2015 10:36 PM
Jacque8080
09-09-2015 09:21 PM
Quick Reply: ?? car seems to studder/in 2nd gear??
