GM STAGE KITs FAQs - Read Me First!
#151
well from what ive read if you run a 2.8 and cold air there is a good chance that you will run lean about 6k-7k and the computer will not like that and you get KR
#153
Originally Posted by Gory
Ive just been doing research on other guys with both and some not all have hesitations and high rpm lean out.
#154
Originally Posted by OniMirage
there may be an issue with the stage tune those people had. There is a false lean/lean code I was recently made aware of that can potentially cause the car to think it is running incorrectly which might be affecting the car in a way that it is running rich when it needs to be lean and running lean when it needs to run rich.
#157
UM yah i like my warenty.
It won't do you any good. They'll just check your tire tread and tell you that you've been abusing the car. If you're gonna go, go all out.
#158
they'll do that ? is there an actual spec for abuse ? what are the exact conditions to quallify for abuse ?
is it subjective ? can a Service manager in a bad mood actually kill your warranty by looking at your tires ?
this sounds too scary and hard to beleive
#159
Edit: Yes there is a spec but I can't remember the number I was quoted. Perhaps some our resident GM techs can chime in with the number.
#161
Holy crap
well thanks for the heads up..
I will be intrested to hear more. I guess it just means we need to mount tires before a warranty claim.. wierd
#162
well i call bs on the tire measurments due to those tires are designed to only last 30,000 km so its even less for miles... the tires are very soft and have AA traction but there soft and life expetency is limited.....if they went by tire wear that dealership should have its head examined.... im a tech at a dealership and thats unheard of... if we really wanted to know what a car was doing we hook up a scanner and see what the car has been redlined too and how fast personally though never seen it done just my 2 cents
#163
well I installed the GM stage 1 and GMsattge 2 belt and 3.0ZZ pulley and NGKplugs with a .040 gap. I also have a K and N intake. I have notice in the last week or so that when I go to give it gas in first gear after havin the car sit over night the car hick ups I then shift to second and it's like the spark plugs do not ignite or the fule does not feed and the car falls on it's face. Then when the car gets running after 5 minutes and it goes away . Anyone else have this problem.?
#164
I have this annoying problem to. I think its just a **** tune. I raced my friend who has the Intense Stage 4 with a 2.8 pulley vs my GM Stage with 2.8 pulley and he pulled on me pretty hard. I think I'm giving up on the GM tune.
#166
No he pretty much walked me! I'm a tech and completely **** about my car so I know she's running at peak. I was PISSED! The only thing wrong with my car is where the factory downpipe 2.5 flange meets my 3" cat back its got a leak, but that should kill my power that much. I'm working on getting this TSB reflah for the Stage kits, but I have no clue what it clears up. As far as the manifold worth in IMO no I would spend a little extra cash and get the ZZ Performance shorty header instead. One thing which bothers me is I have the Injen intake and I keep hearing that it runs the car lean, but I never set a P0171system too lean.
#167
Dyno?
Has anyone dyno's there car after Stage 2? or know roughly what it brings the car up to? I'm not very knowledgable with cars but what like 230-240 HP? less probably? Thanx in advance. -Mike, g3tloose = aim SN. By the way i read through a majority of this thread but didn't see it mentioned, if someone has sorry about that. i gave up a few pages early, was hit with too much info haha... meh bear with me like i said i just got into cars when i got my cobalt.
#169
My car came off the lot with GM stage 2 and other GMPP parts installed by the dealer. I did not ask for them, but glad it had them was going to put on my first cobalt. My question is that since my car had all these upgrades before it ever hit the showroom floor can they still void my warranty? I hope not cause they told me I get the full warranty, hell they even sold me the extended warranty. If they try to void my warranty I think I will own that dealer by the time my lawer is done with them. Just wanted someone elses thoughts on this.
#170
#172
On next Wednesday Im scheduled to install my Stage 2 kit.. amd I going to have to say anything to the dealership? or will they know already about the updated reflash.. is the new reflash everything that the old reflash was or do I need to use both the flash stage 2 came with and the updated.. I just want to be prepared for Wednesday when I get this done thanks!
#173
#174
I just ordered the stage II kit from fredbeansparts for about $600 and I went to my dealer to see how much it would be to install. He quoted me $84 per hour... should I be shopping around and how long will this install take?
#175
