Help understanding all the HEAT EXCHANGERS (information thread)
#76
If you want them to run parallel... you have to mount it using the how to... but i dont think the zzp is a tall heat exchanger, so you may not have to take off the bumper... but either way... you dont have to for either installation, it just makes it easier..
#77
Where is the how to for mounting the zzp H/E? I searched and found for say CX or a cobra but not the zzp....it didn't come with any bolts so do I use the same bolts that are holding the stock ones just those will hold both stock and the zzp? ect.....
#78
If they didnt give you bolts.. thats odd... If you wanna mount in the same place, use the same bolts..
Yea dude they are pretty much all teh same thing... So just use one of those how to's...
#79
#80
No because you would only have the bolts for the stock h/e..
you cant take the bolts off the stock h/e and use them for the new h/e... because then they would be on the new h/e..
#81
#83
#87
I think you have the drift of it...
I dont think this should be removed as the information on this thread isnt wrong... There is some useful stuff on here (you guys bitch about having people search, why take a thread away that they can search from? Do you wanna explain to them about h/e's or do you want to tell them to read this sticky?)
The dual HE setup would yield higher cooling results.. but is more of a pain in the ass to install (depending on which way you go about doing it... read the thread a little bit, it explains everything... and this means from page one)
#88
#89
Edited yes... But others have posted some information on here correcting information... These posts should be saved...
The others yes, i vote for delete.
#92
Hey errbody! First post here on cobaltss.net. I'm new to this heat exchanger stuff. I'm kinda confused. The heat exchangers you guys are talking about, are they intercoolers or are they radiators?
#93
in a nutshell...
#97
i have the gm dual pass with a cobra heat exchanger. i was just wondering how much coolant to put in, also do you just fill the 1 surge tank since it circulates through both? sorry if i sound stupid haha new car!
#99
http://www.crateenginedepot.com/store/pdfs/sidekit.pdf
#100
Check the install guide here. I looked through and I don't see a notice that anything needs to be added but I haven't added this on. I've just done the dual pass HE from ZZP which I added in about 1 gallon of dexcool.
